Thread: Failing the SVA
  #13 (permalink)
Old 18-04-05, 08:20 PM
ti's Avatar
ti ti is offline
Re: Failing the SVA
Blimey Garry !!
I bet you could'nt believe some of these failures ?!?!?
Have you sorted any of them out yet ?
Originally Posted by Safetyspice
Hi Guys,
My fail sheet:
1) Steering column anchorage not strong enough
2) Passengers side lower dash radius not padded enough
3) Wiring behind dash needs clipping a bit better
4) Wire propping open heater flap so no air coming through windscreen vents
5) Reverse taper on track rod end
6) Top ball joint nut not on 2 threads past nyloc
7) Brake pipe requiring one more clip above diff
1 HT lead too close to exhaust manifold
9) Wiring inside boot not secure enough
10) Wiring to front lights needs securing a bit more
11) Alternator charging wire not thick enough
12) Rear reflectors radius not 2.5mm
13) Hazard warning lights go off when main headlights are switched on
14) Another wire under the bonnet needs some more clipping
15) Speedo was inoperable, (sensor probs I think)
AND THE KILLER!!!!!!!!!
16) the seadbelt bracket, the bit that is actually part of the seatbelt and bolts to the top of the car under the roll bar does not have a 2.5mm radius on it!!!!!!!!!!!!!!! and also the plactic cap that covers the bolt again radius problems!!!!!!!!
17) also on the subject of seatbelts, when fastened, they dont retract quick enough
I hope this list is of help to you guys, any questions dont hesitate in asking
Garry
Cheers !!
Terry
