Originally Posted by Kelvincob Hi Purple AK,
That's my problem, there was no ID tags on the box so ID-ing it is hard, I'm sure it's not a WC gearbox & as I said it's been rebuilt, the tail section of the box was set at a 30deg angle so that the gearstick pointed towards the left for yank driver but I've fitted a Cossie T5 tail section which gives me a level gearbox mount, but I would like to make sure I use the correct oil in it.
Kelvin |
AT the right side of the box (mid section) you will see a round casting form that indicates the year (84 or others) you can see that also at the top cover.
At the left side close to the backup switch you can read some casting number something like 13-52-065. OK the last two figures are not the correct tag of your gearbox but are close to it, so your box can be a 13-52-062.
Try at the above mentioned site this combination and you should find the year and application.
One thing is for shore:
NWC use 75W90 and WC use ATF
it is because the changes that B&W made to the synchromesh. The new ones are sintered metal instead of Bronze.
Regards,
CObra289
