| Try a very small cable tie, should work ok. Cheers, Tony
| Or - take a strand of copper from a mains (non flexible) cable, and twist it around the tubing, finishing off by twisting the ends snugly with a pair of pliers.
| Stevie, I think I have some of those exact clips, little ss springs that fit neatly round the tube I saved from my donor car, I'll have a look tonight and let you know. (I've just written "clips" on the back of my hand in permanent marker so I won't forget) Cheers Graham.
__________________ Share your Cobra knowledge here on the Sumo Wiki ...and don't forget, building cars is meant to be fun!! |
| Connect from the pump to a Y junction with the larger tube, buy some smaller tube that fits your washer jets, soak the smaller tube in boiling water and they will soften enough to fit on the Y junction.
__________________ AK 427 FOR SALE AK427 FOR SALE PistonHeads AK for sale Mike AK Sportscars 355 Hauser Chevy The old believe everything, the middle-aged suspect everything, the young know everything. |
| Stevie, if you still need them I found these in the garage: http://homepage.ntlworld.com/chedzoy...erstepdown.JPG ( I couldn't find the springy things) Its a stepdown from about 6.5mm to 4mm and a t-piece in 6.5mm with a stepdown on the other end. This is all out of a sierra. While searching for this I found what was left of the old sierra loom, including a connector that contained the same pins I was after the other day for my ignition that means I don't have to dodge something PM your address if you want these. cheers Graham
| Stainless steel tubing ???? | darren | Pilgrim Sumo Technical Questions | 9 | 18-08-07 03:00 PM |
| Stainless Tubing | Miket | General Cobra Discussion | 2 | 15-07-07 09:13 AM |
| Bundy wiper tubing | RichardG | General Tech Tips & Questions | 12 | 11-06-05 11:57 AM |
| Thickness of Dax supplied Cooper Tubing? | mclark | DAX Technical Questions | 2 | 12-04-04 06:12 PM |
| Break Tubing | AllanR | General Cobra Discussion | 6 | 23-05-03 08:25 PM |
