will give it a go through thanks
David Clifford AK427, Tremec and Stroker. |
wife must have turned the car around !! yes pic of nearside.
Hi,
I'm a bit late, but there's some info here on self centring that explains some stuff, it's for a sumo but the principles are the same in any vehicle: Sumo wiki - Steering I got 30 of my 50 grey hairs trying to figure out my self centring problems so I hope you get it sorted. Cheers Graham
Share your Cobra knowledge here on the Sumo Wiki ...and don't forget, building cars is meant to be fun!! |
Nearside..............no wonder I was a bit confused, I didn't look at the rest of the picture I was looking at the hub and the wishbone. IIRC from when I put mine together your upper wishbones as they are at the moment are reversed. . The larger "knuckle" into which the bump stop used to bolt should be towards the front, you've got it on the back, and the shims should be on the front face of the upper ball joint, not rear as you have them now. That will sort the problem. Cheers, Tony
Why have one cam when you can have twelve of the buggars |
The shims look to be on the wrong side to me. You also need to use the method Ken recommends to measure the angle, there is no correct way it varies slightly from car to car.
East Midlands Area Rep Mega Squirt in and running ! Car Sprayed and looking Fab |
It looks like the bolts holding the ball joint to the wishbone are in the wrong way around, Well, the outer one is anyway.(That is if you are leaving your shims there).
The head of the bolt should always go closest to the shim pack as the disc can get very close to the nut and thread on full lock when the ball joint is off set in the other direction. That's why the original Jaguar bolt had a domed head.
Pro Dax Builder Current builds:- Dax No.123---------Kirkham No. 1 |
That's what I said Dave on post 2.
I re-used the Jag bolts as clearance was minimal even with these fitted. Mine are fitted with the head of the bolts facing forward and the shim pack at the front. Craig.
Dax Tojeiro, + 350 Chevy + Tremec box = no more money! Polishes to date = 14
Oh bugger.
Robin AK427 sporadically in a state of build. |
| steering self centering | graham | General Tech Tips & Questions | 11 | 11-07-03 10:59 AM |
| Tremec Centering Pt II | mikey | General Tech Tips & Questions | 9 | 03-12-01 10:29 PM |
