  #21 (permalink)
Old 21-04-08, 04:44 PM
cliffords cliffords is offline
Originally Posted by RobinH View Post
By all means try moving the shims, but at the end of the day there is no substitute for actually measuring the caster angle which should be in the order of 5 to 7 deg I recall.
As it is set up now, with the shims as they are , I have 6 degrees.
hence the mystery
Thanks
David
David Clifford
AK427, Tremec and Stroker.
  #22 (permalink)
Old 21-04-08, 04:52 PM
craggle craggle is online now
Veteran polisher.
Didn't know you are supplied with an angle to achieve.
Seeing as it's a ten minute job to change the shims give it a try and see what happens.
Polishes to date = 14
  #23 (permalink)
Old 21-04-08, 05:38 PM
Noel's Avatar
Noel Noel is offline
Are you sure that you didn't put a Pilgrim front end on it by mistake???
Noel
Sumo,BAE Chevy 383 Stroker/Roller cam ,
If it's not broken....fix it until it is?
Gallery: http://www.cobraclub.com/gallery/sho...63&page=0&sort=
steering self centering graham General Tech Tips & Questions 11 11-07-03 10:59 AM
Tremec Centering Pt II mikey General Tech Tips & Questions 9 03-12-01 10:29 PM
