Old 17-05-08, 01:14 PM
Carl L Carl L is offline
Engine Bay Wiring
Hi Chaps
Fininsing off the wiring in the engine bay (Last Job)and wanted to check out the following.
I'm using the AK loom \ Huddart 383 stroker with MSD ignition (Built in Coil).
1.Can anyone let me know which wires go to which terminals on the dizzy- 2 spade connectors)?
Carl.
Old 18-05-08, 05:40 PM
Chimeara Chimeara is offline
Carl
You should have a pink, violet/black & a blue/orange wire.
The Pink wire goes to the - neg side of coil for Tacho sender
Violet/black to + side of coil if not using a ballast resitor. If using ballast resistor connect to one side of resistor then take another wire from other end of resistor to + side of coil.
Blue orange goes also to + side of coil but not connected to resistor and only if you are using a ballast resisitor, it acts as a bypass if resistor is employed for cranking. If you are not using a resistor then do not connect it at all at the starter or the coil.
Hope this helps.
ANTHONY
Pro cobra builder
Current build No. 14
www.absolutehorsepower.co.uk
Wiring for first engine start martin_t Engine Tech Tips & Questions 4 26-02-08 11:52 AM
Engine Bay Wiring MarkyC DAX Technical Questions 13 14-02-08 10:32 AM
Engine bay wiring JonnyT DAX Technical Questions 6 14-03-07 04:37 PM
Wiring loom and engine sensors bogster DAX Technical Questions 3 04-05-06 05:47 AM
Can I get rid of surplus engine wiring ? Help ! elans3 Engine Tech Tips & Questions 1 18-06-04 07:17 AM
