Results 1 to 7 of 7
Thread: Master Cylinder
  1. #1
    Cobra fan is offline Spanner Holder
    Join Date
    Feb 2011
    Location
    Blackpool
    Posts
    59
    Master Cylinder
    Hi guys. Im in the process of building a Gen II kit. I'm trying to get the parts ready to get the breaking system done and on AK's website it states that I need a Girling Master Cylinder 3/4" with integral reservoir. I was wondering wheather anyone has used one of these from Car Builders Solutions or knows if this is an adequate replacement for the Girling 0.75 Master Cylinder With Large Reservoir - MA75ILR
    Thanks
    Anthony
  2. #2
    seph's Avatar
    seph is online now Chief Engineer
    Join Date
    Mar 2008
    Location
    Coventry
    Posts
    1,269
    Anthony,
    for the braking system, you need a brake servo from a rover 25. The 3/4" mater cylinder is for the clutch paired with 7/8" slave. A 3/4" master cylinder from ebay for a land rover will do the trick, £20 tops.
    Paul
    AK, Huddart 383 stroker, IVA passed, On the road 27/10/12
  3. #3
    chesterak is offline Chief Engineer
    Join Date
    Mar 2002
    Location
    Chester
    Posts
    1,474
    Quote Originally Posted by Cobra fan View Post
    Thanks
    Anthony
    Consider fitting remote reservoirs as the brake system is difficult to fill under the wing...
    Stan
  4. #4
    Join Date
    Feb 2011
    Location
    Blackpool
    Posts
    59
    Quote Originally Posted by seph View Post
    Anthony,
    Paul
    Thanks Paul.
    Is the Land Rover any year?
    Anthony
  5. #5
    Newtocobras is offline Spanner Holder
    Join Date
    Oct 2009
    Location
    Sheffield
    Posts
    59
    Hi Cobra fan,
    Remote resevoirs can be done like the picture - I put a thread up about how to do this which should be here if you search
  6. #6
    seph's Avatar
    Join Date
    Mar 2008
    Location
    Coventry
    Posts
    1,269
  7. #7
    Join Date
    Feb 2011
    Location
    Blackpool
    Posts
    59
    Paul.
    Thanks for the info
    Anthony
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
