Go Back   Cobra Club Forums > Cobra Wiki > Club Info
Old 04-10-08, 09:40 PM
ƃuılıǝɔ ʎɯ ɟɟo ʇǝƃ`lǝuoıl
Dax sidepipe dismantling Pt1
Right, Lets see if this works. If anyone's still living in the stone age on dial up modems I apologise for the pictures.
I remove my pipes and baffles in the following manner....
1. Remove the screw securing the rear tail pipe section to the outer pipe.
2. Remove the rusty screw at the front that you thought was made of stainless steel.
3. Undo the nuts on the top and bottom of the rear mounting.
4. Support the sidepipe in the middle with a tin of paint and some boxes of rover V8 piston rings. Remove the rear rubber mount from between the pipe and bracket. It will come out if you move the pipe a bit.
5. start wiggling, tugging and swearing at the tail pipe until it slips out the back of the pipe.
6. Now you can see the M5 nut I welded inside here.
TWM Fuel injection now up and running! Sounds and runs superb.
Polishes to date = 27
BB code is On
Sidepipe noise maddog General Tech Tips & Questions 1 27-09-08 11:17 AM
Sidepipe baffles bluetoon General Tech Tips & Questions 7 26-09-08 04:48 PM
Sidepipe slip Stu J General Tech Tips & Questions 6 16-08-08 06:19 PM
sidepipe fitting steve_h Pilgrim Sumo Technical Questions 6 29-07-08 09:54 PM
1st sidepipe Stu J Pilgrim Sumo Technical Questions 3 11-10-07 07:11 PM
