Go Back   Cobra Club Forums > Cobra Wiki
Old 13-04-08, 12:49 PM
dingocooke's Avatar
Ford V8 Engine Data
Here is some general info covering the various Ford V8's you might find in Cobra replica (and the originals), not complete; needs a little help!!
GENERAL ENGINE DATA
CID Bore/Stroke Year Mfg Bore Spacing
221 3.5 x 2.87 62,63 4.38
260 3.8 x 2.87 62-65 4.38
289 4 x 2.87 63-68 4.38
302 4 x 3 68- 4.38
351W 4 x 3.5 69-80+ 4.38
351C 4 x 3.5 70-73 4.38
351M 4 x 3.5 75-80+ 4.38
400 4 x 4 71-80+ 4.38
429 4.36x 3.59 68-72 4.90
460 4.36 x 3.85 68-80+ 4.90
ENGINE DIMENSIONS
Engine Width Length Height Weight Notations
221
255
260
289
302
24 29 27 1/2 460
Boss 302 24 1/2 29 28 1/2 500
351W 25 29 29 525
351C
Boss 351C 25 1/2 29 1/4 29 550
351M
400 26 29 1/2
29 575
332
352
360
361
390
406
410
427
428
27 32 29 625
427SOHC 32 34 30 680
429-460 27 34 30 720
Boss 429 30 34 30 635
4.6 SOHC * 26.9 28.6 600 *28 w/o oil cooler, 29 w/oil cooler
4.6 DOHC 28.9 27.1 29.8 576
Crankshaft PART NUMBERS AND DATA (BASE PART# 6303)
CID Year ID Stroke Main Rod Material
221 260 289 62-68 C2OZ
C3OZ
1M
1MA 2.87 2.2486 2.1232 Cast Iron
289HP 63-67 1M 2.87 2.4286 2.1232 High Nodular Iron, last counterweight may be polished for hardness test. May have orange paint swatch
302 68-69 C8AZ-A 2M 3.00 2.2486 2.1232 Cast Iron
302 70-74 C8AZ-A
2M
2MA 3.00 2.2486 2.12322
302 75-78 2M
Boss 302 69-70 D0ZE-A
7FE-B 3.00 2.2486 2.1232 Forged steel, 69 is cross drilled
351W 69-72 3M
3C 3.5 3.0000 2.3110
351W 73-79 3MA 3.5 3.0000 2.3110
351C 70-74 4M
4MA 3.5 2.749 2.311 Boss and HO have Brinell hardness test mark located on a polished counterweight
351M 75-80 1K 3.5 3.000 2.311
400 71-80 5M
5MA
5MAB 4.0 3.000 2.311
429 68-78 4U
4UA 3.59 3.00 2.5
460 68-78 2Y
2YA
2YAB
2YABC 3.85 3.000 2.500
460 79- 3Y 3.85 3.000 2.500
CONNECTING ROD PART NUMBERS AND DATA (BASE PART # 6200)
Part# CID Weight(grams) Length Bolt Material
C20Z--A
C3AZ--D 221/260
260/289 521-533 5.1545 5/16 Broached bolt seat
C9ZZ--B 289HP
302 Boss 581-593 5.1545 3/8 Spot Faced bolt seat
D10Z--A 302 557-569 5.090 5/16 "Standard Duty"
D0AZ--A 351C 688-700 5.778 3/8 Marked DOAE-A on beam
D1ZZ--A 351C Boss 688-700 5.778 3/8 Marked D1ZX-AA, shot peened, magnafluxed, 180K psi bolts
D1AZ-A 400 846-858 6.58 3/8
Ford Block codes
For example D0ZE- 6015-A (Prefix - Basic part N° - Suffix)
First position (Decade)
B = 1950-59
C = 1960-69
D = 1970-79 (our example)
E = 1980-89
F = 1990-99
Second position (Year of decade)
0 = 70 in our case
Third position (Car line)
A = Ford
D = Falcon
G = Comet, Montego, Cyclone
J = Marine & Industrial
K = Edsel
M = Mercury
O = Fairlane, Torino
S = Thunderbird
T = Truck
V = Lincoln
W = Cougar
Z = Mustang (in our example)
Fourth position (Engineering Group)
A = Chassis
B = Body
E = Engine (our example)
The basic part N°: each part of the engine gets a different basic part number.
In our example= 6015 for a Small-block engine block
The Suffix tells us the change level. In our example, the letter A means "Original" status of the part.
You can also find the date code stamped on the block deck, just above the fuel pump on Ford 221, 260, 289 and 302 Windsor blocks.
Useless trivia: Ford engine names of the 60’s 70’s and eighties indicate the plant they were made in e.g. Windsor. Cleveland, Cologne etc
Steve
We're here for a good time...
Ram 427 SC Sold...Hawk Lemans 289 Sold...Crendon CR427 Chassis no 0029 Sold...cobra less again...will I ever learn.....
BB code is On
How to protect your ID when your personal data has been lost robert General Cobra Discussion 6 22-11-07 08:27 PM
Speeding Data Base oglyoodoo The Cockpit 4 14-04-06 07:39 AM
Data Protection! maverick General Cobra Discussion 5 21-03-06 02:35 PM
Data Protection Scam robert General Cobra Discussion 7 05-11-03 07:50 AM
Ford Windsor 353 data/replica Hallibrand wheel knock off spi nicko General Cobra Discussion 4 04-04-02 03:19 PM
