| Hi Ian, you will have to fit them after SVA because the lights will fail the radius test, and unless you get the units adapted you will still need a separate indicator anyway as the L542 [Hillman] lights only have stop/side and a reflector. HTH |
| I saw an article on this site (I think) where a guy had carefully cut out the middle and added an orange plastic disc so that the flasher flashed orange, but wont solve the radius problem. If you can bear it (wince) your cheapest solution is to fit BL mini indicators and stop lights for sva. the holes can probably be covered by the Imp lenses. Apologies in advance if thats an insult for a crendon build. Kevin |
| Hi Ian Rich is correct in saying the L542 will fail the SVA on radius. What I did for my SVA was to fit the round stop/tail light and the round reflector below and the indicator lower down where it still is. By fitting the rear light and reflector close to each other the mounting holes are well within the area you need to remove for the L542 so no filling required.
__________________ Cheers, Clive (If I'm not here, I'm either in the workshop or on the golf course!) Last edited by Clive; 23-01-08 at 10:10 PM. |
| Ian. Beg, Borrow or Steal some L488 or L594 lights for the SVA along with stickon reflectors Then as Kev said replace then after. The L542's do cover the holes if your carefull. Have a word with GWAK (Gary) on the other site, As he imports them and does a nifty LED conversion to stop/tail and indicator in the same unit for not much money
| Quote:
Kev |
| Thanks for the info guys. Chris (Purple AK) as I am new to all this forum stuff, I don't know who Gary is or what the other site means. Please clarify. I knew the whole idea was going to be complicated, so I am leaning towards fitting the square rear lights after the SVA test and carrying out any body shaping/re-profiling spraying at that stage. Ian
__________________ Crendon 427SC (under construction) SA 452 BBF & Tremec TKO - Is 510bhp enough? |
| Quote:
Gary (user name GWAK) is the guy you need to talk to
__________________ Chris AK 427 351C T5wc Last edited by robert; 24-01-08 at 08:06 PM. |
| The Hillman lights definitely cover the holes on a Crendon. Just fit the SVA round ones and change them later as a winter job. John will have already cut the tail light holes in the body, so all you will need to do is trim the centre part out when you change them. This shouldn't affect the painting of the car, either before or after you change them.
__________________ Crendon, Ford Sideoiler 427 |
| hmmm..interesting thread (for me) this one, as my Crendon (chassis 29 which is the 'new' body shape) has the later Austin Healey type lights which John Kerr drills the holes for, and I have a pair of the Hillman lights from FinishLine (which I also prefer); however, I removed the Healey lights, and offered up the Hillman ones, and whilst you can get them to cover the holes, there is a noticeble flat area of the body moulding at the rear lights, which is covered by the Healey lights, but not covered by the Hilman ones, so this would need to be addressed before paint to get the desired effect later. Id be very tempted in your case Ian, to fit the Hilman lights now (to make the holes blend the body to the lights shape etc) then take them off, and make some adaptor plates or whatever to put SVA compliant lights on for the test. Unfortunately if you leave it until after paint (as my car) its not a quick change (well not for me, so have I missed something, or am I being too picky?)
__________________ Regards Steve We're not here for a long time, We're here for a good time... Last edited by dingocooke; 12-09-07 at 09:46 AM. |
| Rear lights | russj | General Cobra Discussion | 5 | 04-03-06 11:33 PM |
| Rear Lights | NASSTY | General Cobra Discussion | 18 | 04-01-06 10:46 AM |
| Rear Lights | Phil McCann | Pilgrim Sumo Technical Questions | 6 | 13-11-04 04:16 PM |
| Rear Lights | Bigblock | General Tech Tips & Questions | 2 | 15-09-03 08:31 PM |
| Rear Fog Lights | SimonP | General Tech Tips & Questions | 17 | 20-03-03 03:30 PM |
