Results 1 to 8 of 8
Thread: steering boss
  1. #1
    Steve's Avatar
    Steve is offline Technical Director
    Join Date
    May 2003
    Location
    Bridgnorth, Shropshire.
    Age
    49
    Posts
    2,894
    steering boss
    i just priced up a boss for an astra column for my Gd (using same column setup as a crendon) on momo website, cane to £136. is there another alternative
    Steve
    DAX 383 ci SBC 440hp...SOLD
    GD Euro mk4, 427 C.I. LS7, 540 hp...SOLD
    Project Tango "Old School" GD, 440 hp LS3 ....SOLD
    460 HP LS Griff now OTR...roll on summer
  2. #2
    Purple AK is offline Pit Babe Magnet
    Join Date
    Aug 2011
    Location
    East Sussex
    Age
    61
    Posts
    14,946
    Quote Originally Posted by Steve View Post
    Just typed "astra steering wheel boss" into fleabay and came up with 32 results all under £90, some under £30!
    AK427 351Cleveland T5WC
  3. #3
    427jlc's Avatar
    427jlc is offline Mechanic
    Join Date
    Dec 2007
    Location
    cheshire
    Posts
    413
    Hi Steve, which model astra is the steering column from? ( make / model / year?)
    thanks Lee
  4. #4
    bitsilly's Avatar
    bitsilly is offline Chief Engineer
    Join Date
    May 2005
    Location
    Cardiff
    Posts
    1,683
    I butchered the Astra steering wheel which I got with my column from a scrappy. Of all the things and ways I looked at it is by far the best result IMHO.
    I stripped off the rubber/plastic and cut the middle out (circumference to fit the steering wheel), then drilled in the optimum places and drilled the others just to take the bolts.
    I bought one of the Ebay ones and it could have worked if I cut out the middle and was able to perfectlt weld aluminium but I cant!
    I should add the I wanted the steering wheel as far away as I could.
    I will now attempt to attach photos, but by the time this is done everyone else will have sorted you out!
    However, for me as I said it was the best/only solution, and others may like to use it, I'd be interested to get some feedback.
    Ed
    PS, thats just a bit of chromed pipe which fitted over the column, and the housing is simply formed from Al and covered in black leather, it covers the standard Corsa self cancelling mechanism with the arm cut off, drilled, and an MG one epoxyed in.
    Phew!
    Now photos!
  5. #5
    bitsilly's Avatar
    Join Date
    May 2005
    Location
    Cardiff
    Posts
    1,683
    And another
  6. #6
    bitsilly's Avatar
    Join Date
    May 2005
    Location
    Cardiff
    Posts
    1,683
    It seemed the first two were rejected as exceeded my limit, I'll try again.
  7. #7
    Steve's Avatar
    Join Date
    May 2003
    Location
    Age
    49
    Posts
    2,894
    think its the older mk1 astra, circa mid 80s. It is the one which has no height adjuster,
    thanks for the ideas re the steering wheel, food for thought
    Steve
  8. #8
    richard mason is offline Mechanic
    Join Date
    Aug 2007
    Location
    Rugeley , Staffordshire.
    Posts
    313
    Hi Steve
    Would the Astra boss be the same as a Corsa
    If they are the same I have a Momo boss you can have for postage price.
    Richard
  1. Fitting a Steering Boss
    By STEVE W in forum General Tech Tips & Questions
    Last Post: 13-08-09, 12:31 PM
  2. Steering boss
    By sprocket in forum General Cobra Discussion
    Last Post: 18-09-08, 07:48 PM
  3. Removing steering boss
    By mclinc in forum General Tech Tips & Questions
    Last Post: 11-09-08, 08:08 PM
  4. Steering boss
    By chris farrow in forum Pilgrim Sumo Technical Questions
    Last Post: 26-08-08, 05:21 PM
  5. Steering Wheel Boss
    By Martyn-ak427 in forum General Cobra Discussion
    Last Post: 24-08-08, 11:50 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
