| Re: Slave Cylinder & Mounting Bracket Bogster, I have a Chevy small block with a Tremec TKO (not sure about the 500 bit) and bought the clutch slave with bracket from Repower. Might be worth giving them a call. Matt |
| Re: Slave Cylinder & Mounting Bracket Thanks for the info Matt however I am using a Macleod scattershield with the TKO rather than a bellhousing. I spoke with Brian at Repower and there slave cylinder / mounting bracket is not compatible.
| Re: Slave Cylinder & Mounting Bracket Hi Bogster, I have a Ford 393w and tremec 500TKO...and also still looking for the ideal solution. Untill now I have 2 options a) wilwood slave cylinder (www.wilwood.com) but is a pull type b) mechanical (steel wire) The chevy setup should be easier to solve because you need less displacement for the slave due to the ratio of the fork and pivot...Ford setup needs a longgggg stroke...difficult to find such a slave cylinder... So, If you find a simple solution, let me know ! Andy |
| Re: Slave Cylinder & Mounting Bracket No problems Andy, I've been speaking with classicchevy5speed over in California. They can supply me with a slave cylinder for my setup however they have told me that I will have to fabricate a bracket for it as there is not one available which is compatible with a macleod scattershield. Keep you updated Cheers :thumb:
| Re: Slave Cylinder & Mounting Bracket Bogster, Did thet told you which stroke and bore the slave has ? Which master cylinder do you have ? You want to have a light pedal ! So, it's important to choose the right combination of slave and master cylinder. Cheers, Andy |
| Re: Slave Cylinder & Mounting Bracket ..................................This is why I always advise epeople to buy their Tremec gearboxes and bell housings from Repower. However, good luck Bogster, Skorpion.
__________________ Pro Dax Builder Current builds:- Dax No.125---------Kirkham No. 1 Low Volume manufacturer |
| Re: Slave Cylinder & Mounting Bracket I had to make the bracket for my 7/8" slave cylinder to fot on to the scattershield. If it's the same as mine there will be a bracket on the left hand side with threaded holes in it. I made my bracket to fit on to there. :thumb:
| Re: Slave Cylinder & Mounting Bracket thanks for the help. Looks like I'm building a bracket too!
| Clutch slave mounting | Alex Miller | General Tech Tips & Questions | 6 | 15-04-07 04:50 PM |
| Harness mounting bracket | bluetoon | Pilgrim Sumo Technical Questions | 6 | 27-02-07 11:59 AM |
| jag irs inner mounting bracket | phillyassfog | DAX Technical Questions | 2 | 11-10-06 10:37 AM |
| Mcleod Slave Cylinder Bracket | bogster | General Tech Tips & Questions | 10 | 15-04-06 07:56 PM |
| 7/8" SLAVE CYLINDER | bw41059 | General Tech Tips & Questions | 8 | 06-04-04 09:51 AM |
