| Re: Front Damper Unit Bolts Hi Bogster, The 5/8 x 4.5" bolt should be right. The fronts however don't go into a nyloc nut, they secure into the threaded rear support instead. The bolts don't come all of the way to the end of support but there is plenty of thread engaged. On the rear use the same bolt but this time with a nyloc, the thread should project beyond the end of the nyloc without any difficulty. If in any doubt give Dax a shout. Regards SJ |
| Re: Front Damper Unit Bolts Im not sure thats correct for the latest De Dion chassis SJ. The threaded rear support is no more, its all part of the welded chassis now I think. We had the same problem with the bolts being a little short. Make sure you arent using too many of the big washers, we ended up with the bolt into the nyloc but it doesnt have two threads out the end (as I have heard mooted as an SVA requirement!). |
| Flasher unit | steve427 | DAX Technical Questions | 1 | 15-07-07 11:36 AM |
| Heater Unit | lomondbob | DAX Technical Questions | 2 | 29-05-07 05:59 PM |
| Chevy front damper | Clarkson | General Cobra Discussion | 13 | 26-07-05 07:56 AM |
| Front Pulleys/damper etc. | Andy302 | General Tech Tips & Questions | 2 | 23-01-05 07:55 PM |
| Chevy 2 bolts VS 4 bolts | Jesus | General Tech Tips & Questions | 8 | 07-11-02 09:26 PM |
