Old 18-08-05, 11:31 AM
Accelerator Cable fixing
Hi guys,
am I right in thinking to attach the accelerator cable to the foot pedal, I need to cut a slot in the sticky out bit slide in the cable the use a clip or bolt to stop the cable comming out? if not can I get some piccy of wha tIm supose to do
cheers
Ben:thumb:
kreativejuice...
www.kreativejuice.co.uk
Old 18-08-05, 11:43 AM
Veteran polisher.
Re: Accelerator Cable fixing
Hi Ben
What cable are you using? I brought a new cable my 1988 Land Rover 110 V8.
I fitted this cable by simply drilling the pedal arm and using a small bolt and locknut to secure it.
The other end of the cable, onto the carb is the challenge!
Polishes to date = 17
Old 18-08-05, 12:03 PM
Hi Craig,
Ive got myself a universal acelerator cable it has a cylindrical nipple on the end of the cable, so I thought create a slot in the arm, slide it in then one of them there clivis pins or something to stop it sliding out?
I seem to recall seeing somethign like that on a visit to daves place, but my memory does fail me most of the time...
cheers
Ben
kreativejuice...
Old 18-08-05, 12:35 PM
Veteran polisher.
In that case then I guess a slot in the arm for the cable then a plate over the top to hold it would surfice.
My first attempt at placing the cable on the arm was too far from the pivot point so I ended up with hardly any travel. Moving it closer to the pivot will increase the amount of pedal travel.
Old 18-08-05, 01:11 PM
Right, thats something to be wary of then, getting it in the right place I mean....
kreativejuice...
Old 18-08-05, 06:14 PM
Ben,
I had a similar problem with the universal throttle cable and on searching the local breaker's yard found rather a neat plastic clip from a Peugeot 205 accelerator cable at the pedal end. The end of the dax pedal needs to be modified slightly by reducing the thickness or you could trim down the plastic locking clip to fit. Also the ball on the end of the cable needs a slight tweak with a file to provide a pair of flats.
martin
4.7 RV8, Power Steering. was Supercharged, but thats now sold. Megasquirt-n-Spark Extra, running Fuel & Coil Packs in Wasted Spark.
Old 18-08-05, 06:25 PM
Ben,
Found a picture of the clip.
martin
Old 19-08-05, 08:53 AM
Hi Martin,
that looks like just the job, that will be me this weekend then
Whats to stop the cable from poping out the side? is it just that its under tension?
cheers mate
Ben
kreativejuice...
Old 19-08-05, 01:05 PM
Ben,
The ball end on the cable needs a tiny bit of filing I recall, not too much otherwise it will weaken the nipple, but just enough to allow it to snap into place. Even with a slack cable it doesn't pop out the side. Worth a try.
martin
Old 19-08-05, 01:16 PM
Cheers Mate, I'll give it a go!
Ben
kreativejuice...
Accelerator cable mounting to Carb peterol1 Pilgrim Sumo Technical Questions 7 21-08-07 08:17 PM
Accelerator pedal/cable Kevin W Pilgrim Sumo Technical Questions 4 20-09-05 07:19 PM
Accelerator cable bw41059 General Tech Tips & Questions 2 21-12-04 01:49 PM
What does everyone else use as an accelerator cable? Stefan DAX Technical Questions 5 26-04-03 11:32 AM
Accelerator Cable ss083 General Tech Tips & Questions 2 05-02-02 06:38 PM
