Old 19-11-05, 08:38 PM
bogster's Avatar
Clutch master cylinder
Guys,
I am not sure as to which of the Dax clutch master cylinders I should buy. I am installing a Chevy small block 350 with a Tremec TKO 500 gearbox. Should I use the 3/4" or 7/8 bore? I presume the larger bore will provide greater assistance to clutch operation.
Thanks
Bogster
Live the Dream
Old 20-11-05, 10:21 AM
Re: Clutch master cylinder
I had to use the 7/8 with the Tremec, but that was with the repower conversion. Should be the same though.
By the way - are you really doing 430 HP with a 350. I'd ask for the dyno sheet if I were you. When you get it, look at how the power is delivered - if you want a motor that is OK in traffic you may have to advance the cam timing somewhat if it is that radical a cam.
Mine was a pig with the full performer RPM package and that was only putting out around 400 BHP. I've been told from members that fuel injection will improve a very wild cam, but I dont know by how much.
What set up are you on - cam CR etc.
Mike
Mike
Clutch Master Cylinder MarkyC DAX Technical Questions 1 12-10-07 07:23 PM
Clutch master cylinder stabber General Tech Tips & Questions 7 24-01-07 10:58 AM
clutch master cylinder Speedy Gonzales Engine Tech Tips & Questions 0 13-09-06 05:11 PM
Clutch master cylinder cliffords AK Technical Questions 1 06-02-06 07:30 PM
Clutch master cylinder for a Dax PeteT General Tech Tips & Questions 2 30-08-01 12:28 PM
