| Re: Power Steering Let’s see if I understand the EPAS. -DAX use the Opel Corsa B -Normally this unit is linked with the ECU that controls the injection of the car and other systems. -This EPAS can work stand alone. -This unit has standard an integrated “Control Unit” -The unit has the next connections: Live, Earth, Live with ign. on and a potentiometer. -The potentiometer is the trick to adjust the amount of assist. So, if I buy one second had unit and put the potentiometer, at the right place, I am done? Any advice would be appreciated. Regards, Cobra289
__________________ http://www.donostia.demon.nl Cobra289 Gallery "Improvement"¯ means that you recognize previous mistakes! |
| Re: Power Steering QUOTE// Originally posted by Cobra289 -DAX use the Opel Corsa B -Normally this unit is linked with the ECU that controls the injection of the car and other systems. -This EPAS can work stand alone. -This unit has standard an integrated “Control Unit” -The unit has the next connections: Live, Earth, Live with ign. on and a potentiometer. -The potentiometer is the trick to adjust the amount of assist. So, if I buy one second had unit and put the potentiometer, at the right place, I am done? Any advice would be appreciated. //END QUOTE Cobra289 DAX say that they 'Pigggyback' the control and power units. There are several modifications they do to make it work. Perhaps a call to Gary or Peter would tell you what the changes are. I can send you a copy of the diagram and instructions that came with the unit if that helps? Cheers
__________________ Nick Remember - Careless torque costs lives. |
| Re: Power Steering £1,478.90+VAT for the New system £837.40+VAT for the Used (secondhand control unit etc) system
| Re: Power Steering Quote:
Makes AK's aftermarket fitted power steering excellent value for money. :thumb: :thumb:
| Re: Power Steering what do AK charge for their system
That was about 2yrs ago, so prices might have gone up. :thumb:
| Re: Power Steering hi kev thanks for that ,sounds as though the rack is very similar to the one on my pug 405 diesel...!! an external ram is fitted to this too.....a belt driven pump is used here though (probably of no consequence which is used i suspect?possibly more down to what you can get away with on space...!) obviously an easy swap by the sound of it ....... well we can all hope...!! cheers NEIL |
| Re: Power Steering a lot of the peugeot and citreon racks are similair, basically a manual rack with a hydraulic ram affixed to the outside of the casing so you can cut and weld the casing without much difficulty, Also there are a lot of citroens that use an electric pump for the power steeering fluid,
| Power Steering | ryan | Gardner Douglas Technical Questions | 1 | 10-05-07 11:32 PM |
| Power steering? | mickeyg | Newbies | 7 | 27-02-05 03:52 PM |
| Power steering? | mickeyg | Newbies | 15 | 23-02-05 03:22 PM |
| Power Steering | Goldie | AK Technical Questions | 5 | 28-12-04 10:16 PM |
| Power Steering anyone? | kdavies3 | DAX Technical Questions | 20 | 31-08-03 05:56 PM |
