Re: Power Steering
afaik the dax system replaces the upper column, leaving the lower part of the column unchanged,
Steve - AC 04 COB GD Euro, 427 C.I. LS7, 540 hp... |
Re: Power Steering
Hello Bogster,
my de dion has an electric fuel pump fitted i will post a few pictures of its location . as for power steering i havent heard of anyone yet having it fitted. i would like to know if its a worth while exercise as my car is very heavy to drive . at present iam removing my electric pump and going to a manual. thought it was to vunrable were it was situated , plus had problems with it stopping pumping on the odd occasion , and you are usually in the town centre or at traffic lights when it happens. |
Re: Power Steering
Thanks for the pics prodrive :thumb:
When I had the test drive in the Dax De Dion demonstrator early this year the steering was well balanced and I understand that it had the power steering fitted. I think it will be worth it. Thanks again
Cheers, Bogster 2007 Dax De Dion, Chevy V8 Small Block-430bhp, Tremec TKO 500 5 speed, Live the Dream |
Re: Power Steering
Saying that, I don't know if the Dax electric version will have the same feel as AK's BMW rack with fluid pump. Good luck on whatever you decide to do. :thumb:
Mike AK Sportscars 355 Hauser Chevy The old believe everything, the middle-aged suspect everything, the young know everything. |
Re: Power Steering
Bogster, I've fitted the DAX power steering and I have a mechanical fuel pump as well. No problems with the lower steering shaft clearance, (the shaft is the same as non power steering version anyway) It's close but doesn't hit.
The difference in steering effort is amazing. Quiet in operation as well. And easy to fit - which for me is a bonus! I bought for the second hand set up as I'm a cheapskate!! I also went for the mechanical fuel pump as I didn't want to have hassle fitting a fuel cutoff etc etc. My 383 was dynoed at 434hp and runs perfectly with an Edelbrock mechanical unit. Dave B said mechanical was the way to go so that's what I went for. I posted some pics of the lower shaft clearance in an earlier post about mechanical pumps. I can email some to you if you like? Go for it!! Cheers Nick
Nick Remember - Careless torque costs lives. |
Re: Power Steering
Nick,
thanks for the info, could you send me the pics as they would be most useful. What distance from the top and side of the footwell wall did you install the bracket for the steering column? I take it this is very important to position correctly or else the steering will clash with the mechanical fuel pump. thanks for the help Colin
Re: Power Steering
Here you are Colin. The shaft measurements on the engine bay side are 60mm down and 60mm Inboard but if you look at the picture inside the driver's footwell I made sure the bracket was as high as possible, the top left bolt is touching the side if the footwell. Shows how much of a gap I have between the Ally panels and the fibreglass!
Clearance by the pump is about 5mm. Cheers Nick
Re: Power Steering
Hi Nick
What vehicle did you get the power steering off. John |
Re: Power Steering
John, I bought it from DAX but I believe it comes from a Vauxhall Corsa. It's electric not hydraulic.
Nick
| Power Steering | ryan | Gardner Douglas Technical Questions | 1 | 10-05-07 10:32 PM |
| Power steering? | mickeyg | Newbies | 7 | 27-02-05 02:52 PM |
| Power steering? | mickeyg | Newbies | 15 | 23-02-05 02:22 PM |
| Power Steering | Goldie | AK Technical Questions | 5 | 28-12-04 09:16 PM |
| Power Steering anyone? | kdavies3 | DAX Technical Questions | 20 | 31-08-03 04:56 PM |
