| Re: Jaguar 4 speed manual box with electric overdrive? My guess is that it's only worth a couple of hundred quid but I would advertise in a Jaguar specialist forum that's where you'll get the best price. I doubt most Cobrateers will be interested in it for the same reason you are changing it. Best of luck with the sale. :thumb:
| Re: Jaguar 4 speed manual box with electric overdrive? Depends if its a early moss no syncro or a later compact all syncro the latter being worth the most to the Dtype boys but even they are using modern 5 speeds now! But the if you still got jag bellhousing and clutch fork and slave cyl that could be worth a couple of hundred £££ on its own. Adrian |
| Re: Jaguar 4 speed manual box with electric overdrive? There is a way to id the two with the correct id charts but i have no access to that infomation. But normally visually the best way is by the length of the tailshaft of the overdrive unit, basically the older moss box has a long tail shaft and housing on the overdrive unit and the all syncro box has a short tailshaft and housing commonly know as a compact type A overdrive. I would guess you have a later type gearbox because im sure your not double de-clutching to select first gear which is always needed on the earlier moss type boxes. Id advertise it on the jag driver club web site for £200 someone will want it. I still got one under my bench thats been there for years but never advertised it. Adrian |
| Fuel Pump - Manual or Electric | V8 BJC | General Cobra Discussion | 8 | 25-10-07 01:18 PM |
| Edelbrock Carb 600 cfm - manual or electric? | Mr Bling | General Tech Tips & Questions | 8 | 04-09-05 08:54 PM |
| 5 speed manual gearbox | Daxter | General Tech Tips & Questions | 6 | 12-02-05 12:46 PM |
| Electric or manual choke | john w | General Cobra Discussion | 26 | 16-01-05 05:17 PM |
| Borg Warner 5 Speed Manual Box | Olddogjon | General Tech Tips & Questions | 2 | 19-09-03 04:40 PM |
