| Re: Samco Hose Kit Hi Bogster, I didn't take much notice of it the other day, but I flicked through the merlin motorsport catalogue and it suggested that they had pipe kits for certain vehicles and engines - what they were I don't know. Do be careful though - the cost of this hose seems to vary dramatically from supplier to supplier - I think speedflow are pretty competetive. How's the boot lid now? Jon
| Re: Samco Hose Kit As there are so many different options with Kit cars I doubt if any supplier would try to do a kit. With the Dax you could have different engines, Radiator, Heater, Thermostat housing, water pump Etc. If you spend a bit of time you can quite easily work out what you need. If you take a look at my gallery you will see what I ended up with. All were supplied by Think Automotive. www.thinkauto.com Craig.
| Re: Samco Hose Kit I went down the Samco route but did it by buying separately. I didn't go out of my way to find a kit though certainly got the impression that none was on offer. Could be wrong. I found the thermostat to radiator link the hardest to find the correct angles for but got there in the end. Regards SJ |
| Re: Samco Hose Kit Give Europa Spares a call - if you give them an accurate template they can get silicone hose made to the shape and dimensions you need.
| Re: Samco Hose Kit PSH will make any hose you want, but it should be easy to plumb the car with standard hoses. I used a standard black for the bottom hose, as nobody see's it anyway. http://www.performancesiliconehoses.com/
| Re: Samco Hose Kit Hi Bogster I used this company they were very quick on delivery and there prices where very keen at the time . They look the bee's knee's www.siliconhoses.com
__________________ Iain West Midlands Area Rep Dax Owner With A Huddart Engine a smile from ear to ear |
| Re: Samco Hose Kit Here are the sizes that are needed for a Dax with a Chevy engine:- 90 Degree X44mm 2 off bottom hose 45 Degree X38mm 1 off top hose rad end straight X38mm 1 off (You only need about 8" of the 1M length.) top hose stat end That's the radiator sorted. Heaters:- 2x 1m (19mm)lengths (bulkhead-joiner-elbow-engine) 2x 90 degree (19mm)elbows. and 2 joiners (Depending where the heater box is fiitted) header tank. 1X 1M 19mm (Bottom of tank to bottom hose) 1X 1M 8mm. (top of tank to stat housing)
| Re: Samco Hose Kit Well done Dave!:thumb: Can I use that type of pipe for the filler cap to petrol tank??
| Re: Samco Hose Kit I Dave. I don't think so, you'd have to check. It is also no good for servo vacuum hose.........Officially!!!
| samco hose | craigh | General Tech Tips & Questions | 2 | 25-02-07 09:46 PM |
| Anyone got some spare 19mm Samco hose? | steamyrotter | The Loan Forum | 2 | 26-05-06 12:14 AM |
| anyone got Spare black samco hose? | snake_bitten | General Cobra Discussion | 0 | 22-03-06 06:53 PM |
| Samco Superflex | BenBaron | General Tech Tips & Questions | 3 | 02-05-03 05:02 PM |
| Samco Hose | STEVE G | General Tech Tips & Questions | 19 | 26-01-03 06:14 PM |
