Old 08-02-06, 06:20 PM
madjohnny's Avatar
Dax Handbrake cable
Not sure I have the correct handbrake cable. Do I need to modify the handbrake caliper in anyway to allow the Dax supplied cable to fit?
As it stands the U-shaped end of the cable with the cotter pin through it will not go over/engage with the end of the handbrake caliper. Do I need to drill out the swivel part of the caliper that the origianl cable would have gone through???
These annoying bits at the end of a build!!!
Cheers, John.
Drive it like you STOLE it!!
MJ's Gallery
Old 08-02-06, 07:20 PM
madjohnny's Avatar
Re: Dax Handbrake cable
Here's a picture of the "offending" cable.
Have had another look and it doesn't appear to fit correctly at either end!
Even turned it round, still doesn't fit!!!
Cheers, John.
MJ's Gallery
Old 08-02-06, 07:23 PM
That looks spot on to me ( at least the same as the one supplied by AK) I had to drill out the U-shaped end as well for it to be able to move freely.
Old 08-02-06, 07:30 PM
madjohnny's Avatar
Cheers Tinka, can you confirm, did the U shaped clamp on the left in some way fit the handbrake caliper or did you have to remove the bit in between the two halves of the handbrake caliper?
Cheers, John.
MJ's Gallery
Old 08-02-06, 07:38 PM
bogster's Avatar
Hi Jonny
Here are a few pics of how mine is done. Hopefully it will help you. As you can see there is a special L-shaped bracket that is used with the half moon bracket to mate the whole system of cables together. You have to get this from Dax. The Half moon bracket is an XJ40 part. You may know that already though.
Bogster
Live the Dream
Old 08-02-06, 07:41 PM
Sorry for the poor picture of the rear but I think it shows you what you want to know. Yes the U-shaped bracket does fit to the nearside hand brake calliper. HTH
Old 08-02-06, 07:45 PM
bogster's Avatar
Jonny
I've had another look at the cable you have and it's only threaded on one end. The one I is threaded on both ends complete with 2 nuts on each end. I guess you are not building the De Dion version. Therefore I'll be about as much use as chocolate fireguard as the two cables are totally different.
Bogster
Live the Dream
Old 08-02-06, 07:46 PM
Club Sec/Rep Liason
I can't remember how I did mine now. But I would think one side of the U bracket goes in the middle of the caliper arm with the other side on the outside. Hence the long clevis pin to go right through the arm.
Make sense?
AK 427 351C T5wc
Old 08-02-06, 07:48 PM
My pictures are for the XJS,6,12 set up Bogsters are for the De-dion set up that is why they are totally different. Not sure which you have although from the look of your cable it looks like the XJS,6,12 to me
Old 08-02-06, 08:00 PM
dave's Avatar
Tuuurn up da bass.
Hi John.
There are two types of handbrake caliper lever arm, the cable is really designed for the other type of arm, but do not fear. Cut out the swivel part of the caliper arm and slot the cable between the forked end of the arm and then re fit the pin, job done. I have also seen some cars whre the builder has manipulated (Read "Bent") the fitting on the end of the cable so that it fits around the swivel part and then turn the swivel through 90 degrees and fit the pin through the swivel and the cable.
Not the end of the world and can be sorted within a couple of minutes.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Handbrake cable T-Bone General Tech Tips & Questions 4 16-10-07 06:35 PM
Handbrake cable MarkyC DAX Technical Questions 3 06-10-07 03:08 PM
Need Handbrake Cable Iain General Tech Tips & Questions 2 23-09-07 05:12 PM
XJ handbrake cable bitsilly General Cobra Discussion 3 13-12-05 09:27 PM
Dax Handbrake/cable set up Dax SC DAX Technical Questions 4 28-01-03 10:38 AM
