| Re: Dialing in Scattershield Yup! you got it right as far as I remember, Have you drilled and fitted dowels through the scattershield and into the block, so you don't have to redial it in? I didn't bother I just like hard work. The ideal is to have the crank spigot bore concentric with the scattershield bore. Scattershields are heavy ain't they.
| Re: Dialing in Scattershield Two dowels were in place on the block when I started. I haven't had to replace them with offset dowels (thank goodness). Apparently from the information I received from ClassicChevy5Speed (were I bought the gearbox/scattershield) Macleod dial there scattershields in at the factory. I thought you would have to do it for each individual block. However what would I know Anyway I've checked approximately 5 times and each set of checks are approximatley the same and all well within the .005" tolerance. Got the clutch on easily enough now so Scattershield and gearbox on tomorrow night hopefully. That Draper clutch installation tool is very handy for aligning the pressure plate and clutch so you can mount it easily on the flywheel. Recommend it and its cheap as chips too.
| Re: Dialing in Scattershield Knowing what a trial this can be for some folks, consider yourself a very lucky b*****d. LOL
| Re: Dialing in Scattershield Hi Colin. Another part to dial in is often overlooked. the gearbox mounting face of the bellhousing/scatter shield needs to be parallel with the flywheel too. If this isn't right then lining up the hole in the middle will be pointless as the end of the input shaft could be pointing just about anywhere. To correct this you would either need to put shim washers over the bellhousing to engine bolts or get the face of the bell housing machined. ...So go back oput there and do it all again starting with the setting of the box mounting face first. Good luck.
| Re: Dialing in Scattershield I don't even know where Scattershield is. Is it near Rotherham or further north?
| Re: Dialing in Scattershield [quote:99f629e4ba="bogster"]Two dowels were in place on the block when I started. I haven't had to replace them with offset dowels (thank goodness). Apparently from the information I received from ClassicChevy5Speed (were I bought the gearbox/scattershield) Macleod dial there scattershields in at the factory. I thought you would have to do it for each individual block. However what would I know Quite a bit actually as you are right. The bellhousing should be manufactured true if its a good one, its the blocks that vary and movement can change the situation dramatically. Just thank your lucky stars that you dont have to prat around with it. I was also lucky and actually got zero without touching anything. My last car took me two sets of dowels a 'get your head around this degree' and two dial gauges as the first one needed a telling off for getting most of the way around and then bootoming about 4 degrees before the 360 came up. Good luck with it Mike |
| Mcleod Scattershield | bogster | DAX Technical Questions | 9 | 02-05-05 08:38 PM |
| McLeod Bellhousing (scattershield) | dingocooke | General Tech Tips & Questions | 4 | 03-02-05 03:07 PM |
