Old 16-03-06, 08:37 PM
Petrol tank/pipe question
There seems a lot of questions kicking about petrol pipes at the moment, so I thought I would add to it !
I have a Dax tank for a De-Dion, and it has 2 outlets, or should I say 1 outlet, 1 inlet. The bigger pipe is open and O/D 13mm and the smaller one is 8mm and closed. I take it the small one you can open and use as a return for fuel injection. I am at a bit of a loss as to how the open pipe (13mm=1/2") then goes to solid pipe that is supposed to be 3/8" O/D ?
Do you need a 'step down' flexible pipe from the tank to the pump, or does the pump (not got that yet) have an input of 1/2" and output of 3/8".
Hope that all make sense, but I want to run the fuel line along the chassis so I can get the engine in, and get a bit more space in the garage !
Thanks.
Dax DeDion/351W/RPM/Tremmec & R Performance brakes !
Old 16-03-06, 11:09 PM
Re: Petrol tank/pipe question
Hi Mark
I think dax do a fitting, I am making my own tank in stainless with a 3/8 pipe, & much cheaper.
John
Old 16-03-06, 11:17 PM
andy l's Avatar
Hi Mark
Dax supply reducer pipe 13mm to 3/8. most filters used are 3/8 in and out, Dax can supply in line filter but it is small. I got one from Lucas and bolted it between tank / fuel pump.
hope this helps Andy
DAX TOJEIRO DE DION
CHEVY SB 383 STROKER 6.2Ltr 450 Hp
Tremec TKO 3550 3.54.1 Jag Diff
RCR Mk 1 GT 40 in build
Old 17-03-06, 10:51 AM
Thnaks Gents,
Seems strange they fit 13mm then supply a step down. Why don't they just weld a 3/8 pipe in from the start !
Another part to sell you I suppose.
Old 17-03-06, 12:14 PM
My flexible fuel pipe has arrived today and is marked as below.
Does not sound right to me for the SVA, do you know if it is ok?
Cordan Antistatic oil hose 20 Bar WP -9.5mm 46D19
Any good ?
David Clifford
AK427, Tremec and Stroker.
Old 17-03-06, 05:02 PM
madjohnny's Avatar
Originally Posted by mark_biddle
Thnaks Gents,
Good question................Maybe because then they wouldn't be able to sell you an adaptor!!
ps Demon Tweeks also do 1/2" to 3/8" reducers!
Cheers, John.
Drive it like you STOLE it!!
MJ's Gallery
Old 17-03-06, 05:48 PM
Daxman's Avatar
Can you not just run 1/2" pipe the full length car?
DAX DE DION - HUDDART 383
Old 17-03-06, 06:08 PM
Yes could do, but would mean changing the inlet on the carb, not a big job I know. I was more interested as everybody here, and the Dax manual says running 3/8" pipe, so I thought I was missing something. I think my best option is to change the inlet on the fuel pump. 1/2" from tank to pump, then 3/8" from pump up to carb.
Old 17-03-06, 07:06 PM
madjohnny's Avatar
If you're putting a fuel filter in between the tank & pump make sure you can get one with 1/2" connectors as most of them are 3/8".
Cheers, John.
MJ's Gallery
Petrol pipe TINKA General Tech Tips & Questions 18 07-04-05 06:48 AM
Fitting the petrol tank mclark DAX Technical Questions 1 01-11-03 06:22 PM
Leaking Petrol Tank purplepython General Tech Tips & Questions 14 18-02-03 11:16 AM
Petrol Pipe route on GD millsd60 General Tech Tips & Questions 1 23-12-02 05:49 PM
Petrol tank Sealant Mike General Cobra Discussion 3 22-06-01 12:23 PM
