  #11 (permalink)
Old 02-09-06, 05:06 PM
bogster's Avatar
Re: Harness Eye Bolt Problem
Hi All,
As suggested by many on the form I have modified the fibreglass on the rear tunnel and floor pan so that the seat belt anchors can be screwed in. A right pain in the backside.
Ho Humm, :drive:
Picture included.
Bogster
Live the Dream
  #12 (permalink)
Old 02-09-06, 07:36 PM
madjohnny's Avatar
Originally Posted by bogster
Hi All,
Ho Humm, :drive:
Picture included.
I did the same...........Makes it easy to get the rear tunnel section off though! :thumb: :thumb:
Cheers, John.
Drive it like you STOLE it!!
MJ's Gallery
  #13 (permalink)
Old 03-09-06, 09:40 AM
Veteran polisher.
Bogster (what is your real name?)
I am amazed you got the two halves of the transmissision tunnel to fit together so well.
I had to cut and re-fibreglass mine as the two pices were completely different shapes.
Have Dax changed their mould?
Polishes to date = 17
  #14 (permalink)
Old 03-09-06, 11:09 AM
bogster's Avatar
Hi Craggle,
I used a heat gun like the type you use for stripping off varnish, paint, etc. :thumb: If you do it carefully enough you can get the fibreglass like putty, shape it and let it cool. It stays in the new shape just as rigid as before.
I wouldn't like to try it on anything thicker though like a boot lid which needs bent up on both ends.......but I'm thinking about it.
:drive: :drive:
Bogster
Live the Dream
  #15 (permalink)
Old 03-09-06, 12:11 PM
SJ SJ is offline
Craig,
I had the same problem as I had to cut 4 holes in the rear tunnel and then refibreglass to allow it to fit. Turns out that I had been given the wrong tunnel (pre de dion) and Dax agreed to provide me with a replacement tunnel front and rear FOC. They were very helpful putting it right. New one fits like a glove.
SJ
  #16 (permalink)
Old 03-09-06, 04:22 PM
dave's Avatar
Tuuurn up da bass.
Hi Craggle,
:drive: :drive:
Hi Colin.
Do you have gas rams fitted to your boot lid?
If so these will try to distort the boot lid (Even more so if a boot rubber is not fitted)
The way to get the lid back up to height in the two top corners is to tuck some electrical cable (Or small dia. rubber hose) into the seal strip )A few spots of super glue should fold it in place.) this will make it sturdier in those corners and stop the lid from over compressing it.:thumb:
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Which Harness? kevchard General Tech Tips & Questions 8 18-02-07 04:43 PM
DAX willans harness Nobby DAX Technical Questions 2 17-10-06 09:16 PM
willans harness tom General Tech Tips & Questions 9 08-11-04 07:52 AM
2 bolt and 4 bolt mains??? Andy Butler General Tech Tips & Questions 10 12-03-04 09:18 PM
Harness Martin427 General Tech Tips & Questions 4 16-05-01 08:50 AM
