Old 27-04-06, 11:26 AM
Foam in hoops
I am sure that I have seen threads on here that suggest that some people put the expanding foam stuff in the rear hoops before they are attached for to the car. I can't find the thread on here because search doesn't seem to be working. What was the purpose of this and what is the general view about doing it?
Thanks
Old 27-04-06, 11:45 AM
Re: Foam in hoops
Jonny the purpose is to stop teh noise from the rear diff travelling up the roll hoops which are right behind your head. I have heard from others that it is somewhat effective but haven't done it myself.
Nigel B
Old 27-04-06, 12:02 PM
Re: Foam in hoops
Nigel is right - the diff is bolted directly to the frame in our cars, whereas it was in a rubber-mounted subframe in it's original useage. The roll bars bring large amounts of diff noise up to your ears, can be annoying/worrying.
If you don't want to use foam (can be messy), then pulling strips of old carpet through the hoop works as well.
Old 27-04-06, 12:12 PM
chedz's Avatar
Re: Foam in hoops
I went to B&Q and bought a couple of those foam pipe lagging things from the plumbing section and have stuffed them in. They are about 50p for a 1m length and fit inside nicely (the ones for 15mm pipe), they take a bit of shoving mind. They also come out should you ever need to get them out....can't think why you would though
Graham
Old 27-04-06, 12:22 PM
Re: Foam in hoops
Our mast is hollow and the ropes banging against it made a hell of a racket so it is filled with packing beads like a bean bag. I spose it could work and is less permanent than expandable foam.
Just a thought!
Driven it now!! :thumb: He is threatening to hide the keys !!!
Old 27-04-06, 03:29 PM
Re: Foam in hoops
Hi Wilf - trust you are well - seems forever since I've been in the UK anywhere near Cobs but I'll be over in teh summer for a couple of weeks and I'll try and hunt some of you down.
By the way what colour carpet do you put inside your roll bar?
Nigel B
Old 27-04-06, 03:40 PM
RichardG's Avatar
Re: Foam in hoops
If you do down the expanded foam route remember to make sure the insides of the tubes are damp as the foam need it to set properly.
Richard
Welding my bits together
Old 27-04-06, 04:57 PM
tarmacscratcher's Avatar
Re: Foam in hoops
Just a thought!
A sail powered cobra, that's novel.........(kidding)
www.betterbiker.com
Old 27-04-06, 05:53 PM
Re: Foam in hoops
I turned my hoops upside down and filled them with water to get them damp - then drained the water out. With a long plastic tube attached to the foam can, I filled them up by slowly drawing the tube out with the trigger pressed. I get no noise through them at all...
Reverend Robin
GD427 Euro
World Rivnut Champion 2007
Old 27-04-06, 06:42 PM
Wilburn's Avatar
Re: Foam in hoops
Does this apply to all Cobra replicas? I have a Dax De dion build in progress with twin braced roll hoops.
Paul
Paul
DB Replica build 98 - Dax De Dion
David Clarkson - 383 stroker
Barry Grant speed demon carb
Roller Cam
Edelbrock performer air gap inlet manifold
Visit my Cobra photo gallery at paulwilburn.co.uk
Tyre sealing foam Robin427 General Cobra Discussion 6 04-09-07 01:15 PM
Roll Hoops - Foam Filling davealt General Tech Tips & Questions 16 10-08-05 09:33 PM
How do you clean a foam air filter RV846 Engine Tech Tips & Questions 2 22-03-05 12:46 PM
Foam Strips Grease Monkey General Tech Tips & Questions 12 10-05-04 10:33 PM
Side Screens and FOAM Cobra289 General Tech Tips & Questions 4 07-11-02 09:28 PM
