| Re: Wiring loom and engine sensors Hi Colin, We are not using the Dax loom so can't really help on that front. I would expect there to be more than one connection to the alternator however, as there should be +12V plus a sense output which goes to the alternator warning light (in addition to which there will be a thick battery cable). However - I'm sure there are many other ways of doing this so I defer to someone who has a clue on that front! As for thread compound - the important thing to remember is that the sensors work by supplying a variable resistance ground for the instruments. It get's the ground (0V) from the engine, which in turn should have an earth strap to the chassis. You must therefore be very cautious in using thread sealant as it will tend to prevent the sensor from getting an earth from the engine, as it will act as an insulator. The best thing to do if you are worried about leaks is to use a small amount of PTFE tape, as the threads will cut through this. I'm not sure about using PTFE in a hot engine, however, it is what CAE (who make Smiths etc..) recommend. If you have any problems with incorrect readings from your instruments, it will always tend to be an earth problem with the sensor! hope this helps Simon
__________________ www.sounds-legal.com |
| Re: Wiring loom and engine sensors Hi Colin. Your alternator does use the other two wires, look for the rectangular black rubber grommet on the rear outer edge of thealternator and pull it out to reveal two male spade terminals. You will need to use an ignition switched live for the lectric cholke otherwise it will be permanently on as the alternator wires are permanent live. Ditto to the PTFE (Plumbers tape). Just the ticket.
__________________ Pro Dax Builder Current builds:- Dax No.125---------Kirkham No. 1 Low Volume manufacturer |
| Re: Wiring loom and engine sensors Appreciate the advice guys, I went out and uncovered the black rubber cap to find the two connections, plugged in the two additional wires a treat. Glad to know I could use PTFE as I had a couple of roll in the garage from recent plumbing job. I'll wire my choke into the Batt terminal on my Dizzy, I think that is a live ignition conrtolled source...Maybe?
| wiring loom | vinster | General Cobra Discussion | 6 | 15-12-07 01:26 PM |
| Wiring Loom PWS | Marc | General Tech Tips & Questions | 1 | 26-10-06 08:17 AM |
| Wiring Loom Help | shellby_cobra | General Tech Tips & Questions | 12 | 02-09-04 11:17 AM |
| AK Wiring Loom | Steve H | AK Technical Questions | 9 | 09-12-02 08:28 PM |
| Wiring loom | 427sc | General Tech Tips & Questions | 1 | 26-09-02 01:07 PM |
