| Fuel pump mounting bolt size Hi,
I've just noticed that although my steering clears the mechanical fuel pump nicely the outlet on the pump are pointing directly into the chassis webbing and its going to be very awkward to get hose/clamp onto it. It's also not adjustable.
So I've had to remove it and install the electrical pump. However when putting the blanking plate over the mechanical outlet I've found that the larger upper bolts holding the plate are too long. Anyone know what size and type of thread these upper bolts are?
Thanks for the help.
__________________ Cheers,
Bogster
Live the Dream |
