| Re: Template for side pipe outlet Hi Colin. To be safe cut a small hole that will be central (ish) to your down pipes and then open this hole out to the right size by looking up through the hole and sighting the sides of the down pipes. I have a sort of pattern but still finish them off like this. It might look really neat when you have finished if you mike the hole really tight around your pipes but your engine will rock and under load will easily lift by 1/2" or more.
| Re: Template for side pipe outlet Quote:
Well look at that! Just logged on to ask the same question. Want to cut the holes in the body before the lump goes in as it will be tight for space. Dax mk4 body with Dax supplied headers and side pipes. No templates then Dave?
__________________ Ian DAX 454 Chevy Life is short! Break the rules! Laugh uncontrollably and never regret anything that made you smile. |
| Re: Template for side pipe outlet Hi Ian. Cut the holes from the outside, its definately the easiest way, I can't imagine how they could be cut from the inside. I'm sure I've seen a picture in the kit car press of Nigel (Details) Dean cutting his side pipe holes. (I think the current issue of Kit Car? (Where's Den when you need him?)) Follow his instruction, it's bob on.
I'll take a look. Sounds good. Its not so much the cutting from the inside of the wing, its trying to line up the headers and projecting the cut line then marking with pilot holes. Not much room and as I said before, it would be nice to get the body cut and other jobs done before I finally get all of the Cob,s parts back home at my address. Damn builders!! Why are they so slow!
| Re: Template for side pipe outlet Get one of them short magnetic laser levels put it on your header down pipes and mark where the dot is (make sure the thing is in line with the pipe). Then drill small pilot holes 25mm inside the outline then cut the hole and open out to give best fit (as Dave says 1/2" all round)
__________________ john WAHOOOOOOOOO: Got my MSA Licence hillclimbs here I come.......wheeeeeeeeeee! JUST NEED A TYRE SPONSOR NOW>>>> Exhausts & headers made by Mark (fat boy northern) |
| Re: Template for side pipe outlet I used also a template and aligned the headers and sidepipe. It fitted nicely after some hours of sanding/grinding... But after some runs...the headers tends to hang due to the weight of the sidepipe and the sidepipe will rest (melting) on the lower edge of the opening. So my advise is to make it not too big in the begining..after several runs...check how it goes and in which direction you need to adjust. Regards, Andy |
| Re: Template for side pipe outlet Thanks John and Andy. Looks like the lump will have to be in the hole after all.
| Dax Side-pipe mounting. | slogger | DAX Technical Questions | 9 | 04-09-07 12:23 AM |
| Dax side pipe installation | bogster | DAX Technical Questions | 15 | 24-06-06 04:21 PM |
| SVA and side pipe brackets. | chedz | General Tech Tips & Questions | 5 | 19-06-06 02:07 PM |
| Side pipe mounting ??! | PeteV | General Cobra Discussion | 5 | 01-01-06 10:47 AM |
| side pipe repacking | clive a brown | General Cobra Discussion | 9 | 10-03-03 08:04 AM |
