Old 02-02-07, 01:53 AM
Sparticus's Avatar
oil cooler, horns and thermostat help pls
Hi guys,
making a big push on the car towards getting the legendary engine in. Few things i need to do first though and this is where i could do with some assistance:
  • I've bought an oil cooler system and i need to see pics of how to connect it to the small air scoop at the front.
  • Need pics of where to attach the 2 12V horns to the engine bay
  • Pic for attaching the radiator thermostat to the bodyshell
As always your help is really appreciated and i'll stick up some pics after i've done the work as a reference to anyone else
Si
Dax De Dion c/w Chevy 383 - Scaring old ladies, animals and children with the popping from my exhaust
Old 02-02-07, 06:57 AM
Re: oil cooler, horns and thermostat help pls
Hi Sparticus,
If you have a look at our web site u'll see a number of pictures of how to run the pipes and fix the oil cooler. After much discussion on here we decided not to fix it at the top and just used 4 x 6mm cheese head bolts (going in from underneath) with nylocs on top. I think we also put a little bit of rubber matting between the cooler and the body to stop any rattles.
Horn - anywhere you can get it I think is the answer - ours is on the frontward facing face of the inner wheel arch - directly behind the headlamp bowls. Seems to fit ok.
Can't help on the thermostat - I think the one we've got is one of the europa ones which will go in-line in the top hose.
Hope that helps,
Jon
Old 02-02-07, 07:36 AM
dave's Avatar
Tuuurn up da bass.
Si.
You have two holes in your engine bay cladding for the horn brackets to bolt through. (The only holes big enough for an M8 bolt. Also put your engine loom earth loop on one of these bolts.)
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Old 02-02-07, 07:47 AM
They must have forgotten those holes on mine!!
Old 02-02-07, 08:15 AM
Veteran polisher.
I've got twisted steel brackets that connect the top of the radiator to the inner wing panels.
I bolted the horns under these bolts on the inner wing end facing forwards. Sort of next to the radiator really.
Oil cooler was bolted through the bottom of the body and I made small aluminum plates to bolt on the top and then fibre glassed these under the bottom of the large radiator opening.
No pictures unfortunately but could get some tonight if required.
Polishes to date = 17
Old 02-02-07, 08:36 AM
bogster's Avatar
Hi Craig,
I put the horns on the chassis as per the pics, might help. :thumb: I have pics of the oil cooler installation that i can send you tonight.
I attached the thermostat control on the nearside wheel arch aluminium panel (drilled hole and installed)
Bogster
Live the Dream
Old 02-02-07, 08:49 AM
Veteran polisher.
Hi Colin
I dont have those bits on the chassis as mine is non De-Dion but looks like good a place as any to put the horns.
Old 02-02-07, 09:18 AM
Hi Colin - Its all looking very shiny. Great. I like the choice of blue for the operating bits in the engine bay. What colour is it going to be painted?
Old 02-02-07, 09:27 AM
bogster's Avatar
Jonny,
I'm going for a blue as per the attached, without the stripes. Anyone happen to recognise this car? I'd like to find out the colour code.
:thumb:
Bogster
Live the Dream
Old 02-02-07, 10:29 AM
Looks like Tony's car and if it is it is a Mazda blue.
Oil cooler thermostat martin_t Engine Tech Tips & Questions 2 03-01-08 01:26 PM
What type of “car horns” are recommended and legal. the rock doc General Cobra Discussion 3 06-02-07 10:40 PM
Which Type of Oil Cooler Thermostat? madjohnny General Tech Tips & Questions 18 16-03-06 02:52 PM
air horns jiz General Cobra Discussion 2 19-04-04 12:04 AM
Oil cooler thermostat and pipework PAULGD General Tech Tips & Questions 8 12-01-04 06:20 PM
