| sidepipe dimensions Hi Guys, just about got the headers tacked in the right position, can anyone give me an idea of the gap required between the sidepipe and the chassis with the body off? I can guage approximately but if anyone has a build at that stage with pipes mocked up it would help.The other reason is I need to get the angle right because I am using 4 x 2" pipes into the engine bay which limits space against the chassis rail. On another note I have decided to change the high performance iron heads, they are a beautiful ported set but heavy! as we speak a set of Trick Flow street heads are being ported by the Big Ford Guru in the States,cant wait to get them. Dave |
| sidepipes Hi kev, I had the body on to get the clearance by the footwells, which I have chopped back, not a lot of room with the big block so that was fun! once I was happy with the run of the back two on each side, I have the body up above the chassis so I can get on with other work wheeling the chassis outside, the distances I have asked for will get me in the ballpark with pipe/sleeve length. Dave |
| Re: sidepipes Quote:
__________________ Kev AK - 383 chevy |
| Hi Dave. If you are refering to the height the tails of the headers are above the outer rails then between 3/4 and 1"
| sidepipes Thanks guys that helps, also the approximate distance between the sidepipe body and the outer edge of the chassis rail(body off) would be good. Thanks Dave |
| 1st sidepipe | Stu J | Pilgrim Sumo Technical Questions | 3 | 11-10-07 08:11 PM |
| Sidepipe mounting | Stu J | Pilgrim Sumo Technical Questions | 3 | 29-09-07 11:50 AM |
| header/sidepipe fitting on AK | Spanish Dave | General Tech Tips & Questions | 3 | 29-12-06 04:46 PM |
| Patriot Sidepipe Dimensions | kevchard | General Tech Tips & Questions | 0 | 09-03-06 08:12 PM |
| Sidepipe advice - again ! | wires | General Tech Tips & Questions | 5 | 30-05-04 12:49 AM |
