| Brian, no need glass the new scoop to the bonnet, just use rivets, or imho small allen key bolts look very convincing. regarding the filter, I had the dax flat bonnet, hawk scoop combination. I could fit a 14 inch filter with dropped sides. I could not fit a fancy butterfly to the top though, that fouled the bonnet. you do need to make sure the top of the air filter is not so close to the carb inlet that you will get airflow restrictions there. the shape of the top of the air filter is important Also had to fiddle a little with the engine mounts, some make the engine sit 5/10 mm taller in the engine bay than others biggest variable is inlet manifold, think I had the edelbrock rpm on that one. I did spend some time looking at inlets, many would not fit.
| Quote:
__________________ Brian Dax-Built by DB Replicas-No 54 Various Upgrades & Modifications by Me 383ci Delivering Max Smiles Per Mile |
| Brian I cut the hole in the bonnet, and used some fibreall to seal the 8mm gap between the 2 skins. the bonnet scoop remains completely seperate, only bolted on after painting now with the LS engine tin the GD the air filter is right up under the nose, infront of the rad, so no hole cut in the bonnet, just a fake scoop!
| Bonnet Scoop | Dutch Paul | General Cobra Discussion | 8 | 22-07-07 12:28 PM |
| Bonnet air scoop | Bluesumo | Pilgrim Sumo Technical Questions | 4 | 17-03-06 10:01 AM |
| Bonnet Scoop | Bigblock | General Cobra Discussion | 2 | 02-04-03 08:00 PM |
| Bonnet Scoop | 427sc | General Tech Tips & Questions | 1 | 31-12-02 09:34 AM |
| Bonnet Scoop | Steve | General Tech Tips & Questions | 4 | 18-04-02 02:55 PM |
