| Re: Tyre Circumference Quote:
__________________ It's official! British weather has been declared Muslim. It's partly Sunni but mostly Shi'ite. |
| This website is great for working that type of thing out - http://www.miata.net/garage/tirecalc.html
__________________ Kev AK - 383 chevy |
| I have found that the most accurate way to work out revs per mile is to use a bit of driveway and a piece of chalk! The cals are reasonable but can be quite different as tyre pressures vary the rolling circumference more than you would think. Mark the tire and the ground with the chalk and drive through two revolutions of the tyre, mark the ground again and measure the distance. Divide the measurement by two and this gives you a pretty accurate measurement. |
| Hi Warren. 771.84 turns per mile. X 12 gearbox pulses pre prop revolution. X diff ratio. If you are using a Tremec TKO here are the settings per diff ratio. 3.58= 33158 pulses 3.54= 32787 " 3.31= 30657 " 3.07= 28435 " 2.88= 26675 "
| Tyre Wear | Big A | DAX Technical Questions | 26 | 11-10-07 10:23 PM |
| Tyre pressure | Pat | General Tech Tips & Questions | 7 | 16-06-05 09:50 PM |
| Tyre Sizes | BenBaron | General Tech Tips & Questions | 12 | 11-03-05 11:45 AM |
| Tyre pressures | bazbo | Engine Tech Tips & Questions | 2 | 20-12-04 12:20 PM |
| Tyre pressures | ColinH | General Tech Tips & Questions | 3 | 13-11-04 06:56 PM |
