Old 15-05-07, 12:34 PM
Sparticus's Avatar
Have i got the wrong loom?
Hi guys need to know if i've got the wrong loom...have 2 brown wires (one with a yellow stripe) coming from the corner of the wing and also 2 white wires. also at the same point i've got a bundle of 3 different wires.
Have included a pic. BTW its a Chevy engine i've got.
Dax De Dion c/w Chevy 383 - Scaring old ladies, animals and children with the popping from my exhaust
Old 15-05-07, 01:35 PM
Veteran polisher.
You should have got a few pieces of paper with all the colours listed and where they run from and too. If not I could scan mine
I think the brown ones are the alternator, white ones are to the ignition coil or HEl +ve input.
The other 3 may be water and oil sensors but without the colours don't know for sure.
Polishes to date = 17
Old 15-05-07, 01:43 PM
Sparticus's Avatar
Update: the three branches of wires coming off at the corner of my inner wing are as in the pic above:
1/ White
White + Yellow
White + Black
2/ Brown (approx 5mm thick)
Brown + Yellow
3/ Blue + Dark Green
Light Grey
White + Brown
None of the above wires end in terminals (except the white, white+yellow, White+black)
Theres a big wire also (coming off the black box thing i've fitted above the transmission tunnel). On it is...
4 brown wires finishing in a ring terminal
White+Yellow
White+Red
Old 15-05-07, 01:59 PM
Veteran polisher.
1/ White = Ballast resistor or +ve input on HEI Distributor
White + Yellow = Ballast resistor or coil to start solenoid to give 12 v boost whilst cranking with a 6V coil. (not used on HEI distributor)
White + Black = coil to rev counter
2/ Brown (approx 5mm thick) = Alternator main output
Brown + Yellow = alternator to charge warning light
3/ Blue + Dark Green = water temp sender to gauge.
Light Grey = Oil temp?
White + Brown = oil pressure switch to warning light
4 brown wires finishing in a ring terminal Same connection as main battery lead on starter solenoid
White+Yellow = other end of white and yellow mentioned above
White+Red = Starter switch to start solenoid.
I have attached the document that all these colours come from.
Old 15-05-07, 02:12 PM
Sparticus's Avatar
so have Dax sent me the Ford loom instead of the Chevy?
Old 15-05-07, 02:15 PM
Veteran polisher.
Looks like the chevy loom to me.
I had to modify quite a lot of this as I removed unused wires such as the starter to coil lead as I used an HEI distributor and I used all mechanical gauges so removed all those wires too. I also added an ammeter, Central ignition key mounted in the dash and a start button.
CRaig.
Old 15-05-07, 02:18 PM
Veteran polisher.
I also found that some wires didn't come out the main loom n quite the right place. It is a simple enough to unwrap the loom and route them where you need then re-wrap the loom again.
Have I done something wrong? clive a brown General Cobra Discussion 1 30-05-07 04:59 PM
Something wrong? the rock doc The Cockpit 0 22-04-07 08:18 PM
Now thats just wrong! simon General Cobra Discussion 3 02-01-06 12:13 PM
Wrong fuel tank or wrong brackets? craggle DAX Technical Questions 4 15-08-04 08:43 PM
Being In Wrong Place At The Wrong Time......... Colin GD427 General Cobra Discussion 15 16-06-04 09:01 PM
