Old 21-05-07, 06:54 PM
Lloyd Barnes's Avatar
Copper Fuel Pipe
Hi all
could do with some help on fuel pipes. Have seen (I think it was one of Dave Brookes posts) that 10mm microbore copper tubing is the way to go for the fuel lines back to close by the tank, then finished off with fuel pipe.
Should I be swaging the ends of the tubing to stop the pipe blowing off and if so how? using a chevy with carb so guess not too high pressure but would rather avoid the whole thing going up in flames!
Lloyd B
Lloyd B
De dion Dax - 383 SBC with AFR 195's, not finished but driveable, frightened passenger count, 1!
Old 21-05-07, 07:23 PM
Sidecarbod's Avatar
Re: Copper Fuel Pipe
Originally Posted by Lloyd Barnes
Hi all
Lloyd B
I doubt that 5 or 6 psi is enough the blow the pipes off. Just make sure that the flexible hose is a good fit and that you push it on about 30 mm. You could also use two clips as a belt and braces job.
If you insist on having some sort of end on the pipe you could get a 2mm wide piece of copper pipe and stretch it over the end of the actual copper fuel line then solder it in place. To stretch the 2 mm band you would need a bit of tapered steel rod that you can force it over.
HTH,
Pete
Old 21-05-07, 07:34 PM
Hi all
Lloyd B
an other option is to get a couple of bolt on fittings and crush the olives onto the pipe then remove the fittings leaving the olive behind.
Old 21-05-07, 09:20 PM
kevchard's Avatar
I soldered on a couple of brass olives (as used in central heating plumbing etc).
Worked a treat .
Kevin
Kevin & Helen
DMS Venom Viper
Granada Cosworth 2.9V6 BOA
SVA passed Aug 07
Old 21-05-07, 09:50 PM
dingocooke's Avatar
Copper used to be a very popular 'rigid' fuel pipe; just be very careful that the ends which have flexibles attached are very well secured so that the movement from the flexibles cant flex the copper and fatigue it; the main reason why its not widely used anymore.
Steve
We're here for a good time...
Old 21-05-07, 09:54 PM
aha, never thought of using olives. thanks all, I'm sure the two clips would work but this seems like one area to be belt n braces
Lloyd
Lloyd B
Old 23-05-07, 02:47 PM
Hi,
I contemplated copper pipe for my brake / fuel lines but was advised by this & other forums Cunifer, (excuse the spelling) is superior in a number of ways to copper.
Regards,
Martyn
Old 23-05-07, 03:47 PM
Cunifer - is that just copper-plated steel? Or is it a different alloy? I recall that it work hardens even quicker than copper.
Old 23-05-07, 03:58 PM
Orange Cobra's Avatar
"The material Cunifer is an alloy. The name is derived three principal elements copper (Cu) nickel (Ni) and iron (Fe). "
Anti Radar Paint,SBF 393,TKO600, Nobody can stop us now , nobody!!
Securing copper fuel pipe to rubber hose kevchard General Tech Tips & Questions 23 06-05-05 12:53 AM
Copper Fuel Lines arowland General Tech Tips & Questions 4 28-02-05 05:48 PM
1/4 inch copper brake pipe. simon General Cobra Discussion 7 05-01-05 10:54 PM
how much PSI can Rigid copper pipe take? chris m General Tech Tips & Questions 7 19-08-04 08:40 AM
Copper Pipe David J General Tech Tips & Questions 5 28-02-03 10:29 AM
