Old 23-05-07, 09:53 PM
Sparticus's Avatar
Mega Fire Ignition - Help please anyone
Trying to run the electrics for my engine at the moment and i'm not sure where the cables from my "mega fire" ignition system go. Heres a breakdown of what i've got already from my wiring loom:
1/ white cable x2 - (have joined together because not using a balast resistor)
2/ White/Red - S terminal on solenoid
3/ White/yellow - (Now blanked off)
4/ Brown (large with ring terminal) - Starter motor
5/ White/Yellow - (blanked off as i won't use balast resistor)
6/ White - BAT on Distributor
7/ white/black - TACH on distributor
NOW..... on the mega fire ignition:
1/ Black (ring terminal) - Battery negative
2/ Red (ring terminal) - Battery positive
3/ Green + Purple wires - To bottom of distributor
4/ Thin Red - keywire ( apparently attches to key ignition barrel?)
5/ Thin White - Do i not use OR have it go to distributor negative?(Instructions say for "points and electronic distributors" the white wire goes to points or distributor negative. For "Magnetic pickup distributors or crank triggers" i don't need the white. How can i tell which one i use.... i have the purple and green wires so i'm guessing i've got magnetic pickup or crank triggers ???)
6/ Thin Brown - Tacho input (instructions say "Do not attach tachometer leads directly to Coil, it will destroy tachometer!!!!???? wtf?)
7/ Black - Coil (-) (where does this go????? still to the negative on the distributor?)
8/ Orange - Coil (+) (where does this go????? still to the positive on the distributor???)
HELP!!! SOMEONE!!!!!
Si
Dax De Dion c/w Chevy 383 - Scaring old ladies, animals and children with the popping from my exhaust
Old 24-05-07, 07:38 AM
tonym's Avatar
Disillusioned
The colours seem the same as on a msd unit in which case,
1 black to negative side of battery
2 red to positive side of battery
3 green and purple to distributor if using magnetic pick-up dizzy (normally two wires coming out, but no ides what dizzy you're using)
4 thin red wire to switched 12v, ie only live when you're ignition is on and cranking
5 thin white to dizzy if you're not using the green and purple wires, use one or the other, again don't know what dizzy you're using
6 brown wire goes to tachometer input
7 black coil negative goes to the negative terminal on the coil
8 orange coil positive goes to the positive terminal on the coil these are the only wires that go to the coil
HTH
BIG TONE
Gallery
Old 24-05-07, 09:46 AM
Sparticus's Avatar
Thanks very much. Just what i needed to know.
only one question....you know how you say the thin black and thin orange are the only ones that go to my coil....Does that include the ones from the wiring loom that would normally plug into TACH and BAT on the distributor? Do i not plug these 2 wires in any more?
Many thanks,
Si
Old 24-05-07, 06:09 PM
tonym's Avatar
Disillusioned
Si, Sorry i can't help there, perhaps someone with your loom/dizzy can help, I'd hate to steer you wrong.
BIG TONE
Gallery
Old 24-05-07, 08:07 PM
Banned
Wire'n up Mega-Fire box to HEI dizzy 101
Yes Tony...Mega-Fire box wires up to Chevy HEI just like MSD boxes
NOTE*** REMEMBER TO ALSO INSTALL COIL GROUND STRAP FROM COIL TERMINAL IN CAP TO GOOD CHASSIS GROUND , THIS IS THE MOST NOT DONE THING WHEN WIRE"N UP THESE SYSTEMS. / DRIVES YOU NUTS!
IT IS THE MIDDLE TERMINAL BETWEEN COIL + & COIL - MARKED ON CAP.
PLUG IN CONNECTOR TO THIS TERMINAL AND THEN TO GOOD CHASSIS GROUND../ eg ground strap to block is good choice.
Failer to ground coil in this way will leed to mid & high RPM miss fires and hard starting and other fun stuff
*Fee for this lesson 1 shaved BBQ pork sandwich & 2 pints local brew.
Cheers! Dr,Dee
ENJOY SIMON...beers on you!
HTH[/quote]
Old 24-05-07, 08:34 PM
SJ SJ is offline
Si,
Can't be sure not knowing the details of your loom, though as a general rule, if you are wiring in an ignition system using its primary wiring you don't need to connect the loom wires allocated for the coil. Certainly didn't on mine using an MSD 6A ignition and it works just fine.
SJ
We all talk of mega horsepower. the rock doc The Cockpit 0 31-05-07 02:42 PM
Mega Mamas Movies!! megamamas General Cobra Discussion 0 15-01-07 07:40 AM
fusible link/mega fuse position Daxman DAX Technical Questions 2 02-01-07 08:24 PM
Finally got Mega running like a dream TINKA Engine Tech Tips & Questions 12 03-11-06 10:29 PM
Fire engine Louise The Cockpit 0 16-03-04 12:56 PM
