Old 05-06-07, 08:19 PM
Nigel Foster's Avatar
Bottom Hose from Rad tovia De Dion to Ford 351W
Holy Sh..t , seems to me to be veritable assault course for the very expensive blue silicone pipe I am using . It isn't a clear route, What is the best method or has someone pictures and would kindly forward to assist a dumbo finish the project ,.................... nearly !!
Nigel
Nightfire Red and Silver Striped Toj - It's in the Blood !!
SBF351W/TREMEC600
Passed SVA 11/04/2008
Old 11-06-07, 02:54 PM
Re: Bottom Hose from Rad tovia De Dion to Ford 351W
Come on Guys ....... What has no one anything to add?
Nigel
SBF351W/TREMEC600
Old 11-06-07, 05:10 PM
Clive's Avatar
Hi Nigel,
I used silicone hoses either side of stainless steel pipe for my bottom radiator/engine route on my 289 with Ford 302. Helps to keep the cost down!
Cheers, Clive
Old 11-06-07, 07:35 PM
Orange Cobra's Avatar
Howdy
For my Pilgrim I used SS Flexpipe. Didn`t leak under pressure (unlike myself )
http://store.summitracing.com/partde...5&autoview=sku
Best Regards
Frank
Anti Radar Paint,SBF 393,TKO600, Nobody can stop us now , nobody!!
Old 12-06-07, 04:12 PM
Hi Nigel,
Sorry not noticed this before. We are using the 351W engine also with the Dax rad (albeit the old steel one rather than the new ali one but I suspect they are similar in design).
There are some pics on our website of this piece.
We came out of the water pump with a long legged 90 deg bend. This if positioned correctly, because of the angle of the pipe from the water pump heads downwards. A similar, long legged bend at the other end was used off the rad. Between the two we used a length of stainless pipe.
There are pics on the website. However, basically the s/s has a bend (cut and rewelded) at each end, each about 30 degs from memory, although the one at the water pump end is less than rad end. The bends are not straight either - the one at the water pump ends kicks by about 10 degs or so to the nearside. This then allows the pipe to go above the steering rack.
The straight bit in the middle then fixes to the chassis cross members at the front below the de dion beams. I made a mock up out of mop stick, a hot glue gun and a lot of trial and error. A friendly coded welder then made it up for me. It is very fiddly and time consuming, but does produce a very neat result in the end. It also keeps the pipes pretty much out of harms way.
The take off for the header tank was also welded into the bottom section of the pipe. I can take some pics of the mock up tonight if that would help.
Jon
Old 13-06-07, 01:55 PM
Originally Posted by JonnyT
Hi Nigel,
Jon
Very Useful . Thank you very much.
Nigel
SBF351W/TREMEC600
Old 13-06-07, 01:56 PM
Originally Posted by Orange Cobra
Howdy
Best Regards
Frank
Thank you very much
Nigel
SBF351W/TREMEC600
Old 13-06-07, 01:57 PM
Originally Posted by Clive
Hi Nigel,
Thats Great , Thank You very Much
Nigel
SBF351W/TREMEC600
Old 11-07-07, 03:14 PM
Arrow Flexible Hose
hello Nigel, i have bought some flexible stainless steel hose for the this very job on my SBC dax like the stuff mentioned previously in this thread. It looks like a thick shower attachment hose. i have not fitted it yet and would be interested to see some pix of your installation if you have time to take some.
thanks
...ac427
Old 11-07-07, 05:21 PM
Red face
thanks
...ac427
We have a slight problem in that you have a Chevy and mine is a Ford with the outlet in a completely different location. I followed Jonny T's description for the Ford and it worked a treat but not a lot of help on a Chevy .Sorry
Nigel
SBF351W/TREMEC600
AK 350/SD1 Radiator bottom hose dorian Newbies 4 08-10-07 05:43 PM
Bottom Radiator Hose lomondbob DAX Technical Questions 11 26-09-07 07:49 PM
De-Dion Toj and Engine Factory 351W Nigel Foster DAX Technical Questions 4 09-03-07 09:39 AM
Bottom radiator hose to water pump on SBC AC427 DAX Technical Questions 7 11-08-06 08:56 PM
Ford 351W Shaney23 General Cobra Discussion 3 01-05-04 07:22 PM
