| Hi, are you using a newer steering column (round hazard button) or the older type (square hazard Button)The reason is i beleive if you wire up the newer column as per the dax instructions it constantly blows fuse's. You have to modify the dax loom and add a relay (easy job), to use the newer column. I have a diagram showing you how to modify the loom if you need it. Russ
| Talking of electrics going up in smoke. Half way through my Sumo build, last week I turned the key to ignition and smoke started billowing out of my wiring loom. Reason. Have a mallory ballast resistor bolted to my bulkhead. Turned out the ceramic core was not held securely by the clamp which attaches it to the bulkhead. The core had slide down inside the clamp until it jammed against the positive terminal bolt. On turning the key a fair old amperage when straight down the ignition wire shorted against the bulkhead frying the wire and resulting in me having to pull apart the loom (for hours) to sort out the wiring damage. Very Pi55ed off. So if you have a Mallory balast resistor you may want to make sure the ceramic is well clamped! |
| i've got the round hazard button and am currently using the dax additional relay. Think i might have forgotten to plug in one of the live wires to pin 30 (apparently) which will be why my side lights aren't working. Still not sure why flashing my headlights causes the fuse to pop though.any ideas
__________________ Dax De Dion c/w Chevy 383 - Scaring old ladies, animals and children with the popping from my exhaust |
| It might be possible that when you go to flash your headlights you're getting a dead short, thus popping the fuse. First thing I would do is carry out continuity checks on the headlight circuit. Also check that none of the feed(live) wires are going to earth. Russ
| Quote:
Are you sure the bulbs are the correct type also?
__________________ jason A Dog is not just for Christmas; If sliced thinly enough, it can last until Easter. Dax TojSBC 377 3550 BOx |
| Hi Simon. Switch off the hazards (if they are on) before switching the high beam flash and see if that cures the fuse problem.
| Success!!! Cheers Si
| No worries Simon. It's always (A) good (Laugh) when you ring.
| It works | markr | Pilgrim Sumo Technical Questions | 11 | 07-12-07 09:50 AM |
| It works ! ! ! | Stu J | Engine Tech Tips & Questions | 4 | 23-11-07 09:54 AM |
| It Works!!! | Nobby | DAX Technical Questions | 0 | 24-10-05 01:45 PM |
| YEAH!! it works!!!! | BenBaron | General Cobra Discussion | 3 | 22-06-05 11:33 AM |
| Water works.... | BenBaron | General Tech Tips & Questions | 8 | 14-12-04 01:39 PM |
