Old 27-06-07, 11:31 PM
SJ SJ is offline
Sump Removal
Does anyone know whether it is possible to replace the sump/gasket of a 383 chevy engine from the underside of the Dax De Dion chassis? I cracked my sump whilst in France and having got a new sump pan need to go back to repair it. Not having done this before I wanted to check that its physically possible with clearances, access to bolts etc. Is it a straight forward job?
Can't look at my own car as it's stuck in France!
Thanks
SJ
Old 28-06-07, 08:16 AM
Veteran polisher.
Should be very easy.
remove the oil filter to give more room (you will be changing it anyway as you will be changing the oil) and all the bolts are easily accessible.
Just make sure everything is clean and oil free before replacing the gaskets and you should be fine. I believe some silicone is required for the join between the cork and rubber seals.
Polishes to date = 17
Old 28-06-07, 10:56 PM
SJ SJ is offline
Craig,
Many thanks. I'll let you know if I'm successful. Operation Recovery has the green light from the wife for this weekend.
SJ
Old 29-06-07, 11:09 PM
Clarkson's Avatar
Speed junkie
Originally Posted by SJ
Craig,
SJ
Have you left it parked on the side of the street??
David
2nd baby due 23rd Jan.
Old 01-07-07, 11:54 AM
SJ SJ is offline
Fortunately no. I hit a metal stump in the middle of a gateway into a hotel we were planning to stay in. We left it in the hotel car park which was pretty secure (locked gates overnight). I collected it successfully yesterday and everything was as I left it with no damage.
I trailered the car back in the end; no problem with customs.
SJ
Old 01-07-07, 03:28 PM
Veteran polisher.
Glad you got it back safely SJ
I couldn't sleep at night if I didn't know my car was safely locked in the garage at home! Guess you didn't have a choice though.
Good luck with the sump replacement.
Gearbox Removal cperry Pilgrim Sumo Technical Questions 21 11-02-08 04:30 PM
T56 Removal jamesLS7 Gardner Douglas Technical Questions 5 17-10-07 06:22 PM
Loctite 243 removal Spanish Dave General Tech Tips & Questions 6 18-09-07 09:32 AM
Mk2 Winscreen removal blue Pilgrim Sumo Technical Questions 4 25-06-04 11:44 PM
Help please...flywheel removal ColinHudson General Tech Tips & Questions 6 07-02-04 05:02 PM
