| Not done it with a Tremec but have had my ZF 6 speed in and out a couple of times, easiest way I found was to take off the steering wheel, undo the nuts holding the dash in place and remove dash after undoing wiring multiplugs, remove tunnel, undo propshaft from diff and remove then undo box from engine/mounts, slide back and lift out. Engine stays in place but will need supporting at the back. As the 6 speed is a large box I would im agine the Tremec would be as easy if not easier and the advantage is that you do not disturb the engine connections, exhausts, water etc. Hope that is of help, cheers, Simon |
| Quote:
Why did you have to remove the gearbox to have the car painted ![]()
__________________ AK 427 FOR SALE AK427 FOR SALE PistonHeads AK for sale Mike AK Sportscars 355 Hauser Chevy The old believe everything, the middle-aged suspect everything, the young know everything. |
| Quote:
Hopefully not in the near future but at some point I will have to do the above when it comes time to recondition, etc.
| Gearbox Removal | cperry | Pilgrim Sumo Technical Questions | 21 | 11-02-08 03:30 PM |
| T56 Removal | jamesLS7 | Gardner Douglas Technical Questions | 5 | 17-10-07 05:22 PM |
| Flashline Removal | steve.hills | Pilgrim Sumo Technical Questions | 2 | 04-01-05 04:15 PM |
| RV8 gearbox removal from a Sumo | beanpole | Pilgrim Sumo Technical Questions | 20 | 13-05-04 01:45 PM |
| Rover gearbox removal | DrFelch | General Tech Tips & Questions | 8 | 20-02-04 06:33 PM |
