| Height of Radiator The lower cradle for my radiator is U-shaped with two horiziontal lips at each end. The overall width is too wide to fit within the overrider horns. But it will fit underneath. This leaves the lower part of the radiator level with the bottom of the chin scoop but the ends protrude when viewed from the front. Also, there is a good clearance between top of the radiator and body. Looks like I'll have to split the cradle, cut out a short section and weld back up. Then the radiator can be held higher by resting the cradle on top of the horns. This should leave teh raditor not visible from the front and a slight incline backwards. So, the point of my story is to determine the exact height of the radiator. For example, should it be completely occluded when the car is seen from the front? And what kind of incline at the top is required? Half an inch, one inch, two inches?? Bob
__________________ "If you're in control then you're going too slow - Mario Andretti" |
| Quote:
| Get your dictionary out young man..mine says: 1. To cause to become closed; obstruct: occlude an artery. 2. To prevent the passage of: occlude light; occlude the flow of blood. 3. Chemistry To absorb or adsorb and retain (a substance). 4. Meteorology To force (air) upward from the earth's surface, as when a cold front overtakes and undercuts a warm front. 5. Dentistry To bring together (the upper and lower teeth) in proper alignment for chewing. v.intr. Dentistry To close so that the cusps fit together. Used of the teeth of the upper and lower jaws. Although Im not quite sure if the context Bob used it in is really right; Im guessing he meant getting it in a position so that that the rad completely filled the opening around it when viewed from the front??
__________________ Regards Steve We're not here for a long time, We're here for a good time... Last edited by dingocooke; 23-07-07 at 06:33 PM. |
| Quote:
Surely "closed" would have been enough. ![]() Some of you guys use some long,complicated words sometimes - I`m sure you just make them up. Apart from Sir Wilf that is - his vocabulary is always right - I think. ![]()
| Quote:
Mine is the same. If it helps, the cradle goes on the outside of the chassis horns. |
| Thanks John. I seem to have confused some with the word 'occluded'. I meant 'not seen'. But you have answered my question by saying that the lower corners can still be seen from the front. I think I still need to get the radiator a bit higher but my cradle will not fit on the outside of the horns. The 'U' is too wideto go between and too narrowto go outside. It looks as if the two horizontal lugs are designed to be bolted to the lower face of the horns. I think I'll just cut and weld so that I can fit it between the horns then the lugs will rest on to of them. A single bolt on each side should secure it. And this will raise the radiator about 5cm. Bob
| Quote:
![]() Why are you trying to hide your radiator? - Is it a secret radiator? ![]() ![]()
| no; simply put, it was excluded from an occult gathering in its home village of Serck Marston by its elusive parents who colluded to occlude it from any public contact, causing acute embarrasment to its very core in later life whenever its corners were exposed; well that was my conclusion.. ..just coming matron...
| Ride Height | JonnyT | DAX Technical Questions | 14 | 22-11-07 03:50 PM |
| Pedal height? | kevchard | Viper Tech Forum | 13 | 09-08-05 06:51 PM |
| roll bar height | David J | DAX Technical Questions | 4 | 25-01-04 12:38 AM |
| Low-height air filter | ian | General Tech Tips & Questions | 29 | 20-11-03 09:00 PM |
| Ride Height | wilf | General Cobra Discussion | 2 | 27-01-02 10:04 AM |
