Old 02-08-07, 08:42 PM
Ready to drop in engine?
I don't want to put in the engine only to find I've forgotten something that should have been located first. This is what I've done so far:
Body on permanently
Both axles complete
Propshaft in place
Alloy engine bay panels in place
Pedal box in place
Servo, master cylinder and brakes lines in place
Clutch master cylinder in place and hose attached
Expansion tank in place
Radiator in and top brackets located
Bonnet hinges in place
Screen washer bottle in place
Horns in place
Thermostat in place
Fuel line in
Battery lead (+ve) in place
I have not located any wiring/fuse box or positioned the gearbox mount. What do your think? Is it time to drop in the engine/gearbox yet? Thanks.
Bob
"If you're in control then you're going too slow - Mario Andretti"
Old 02-08-07, 08:57 PM
Veteran polisher.
You've done a hell of a lot more than I did before fitting the engine so I guess the answers yes!
I did mine a bit different. I.....
Ran brake lines, battery and fuel lines.
Temporarily fitted body and fitted engine bay lining and Bonnet hinges
Removed body and permanently fitted engine and gearbox.
Permanently fit body by lifting over the engine.
Complete the rest!
I think you will be safe to get the engine and box in.
Polishes to date = 17
Old 02-08-07, 11:18 PM
dave's Avatar
Tuuurn up da bass.
Go For it Bob, you are on a roll.
Why don't you fit the loom? It is much easier if you can climb into the engine bay.
If you are worried about the drop out points for the engine loom give me a call (9-5) and I'll explain where to run it.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Old 03-08-07, 12:54 AM
Sparticus's Avatar
alternatively pop round and i can show you how i'm getting on. Not much left to do.
Si
Dax De Dion c/w Chevy 383 - Scaring old ladies, animals and children with the popping from my exhaust
Old 22-08-07, 12:06 PM
You can still do more.
The wiring loom as dave has already suggested is a lot easier to put in now. I also struggled to fit the luvres in the side of the body once the engine was in. My expanding waist line was a bit of an issue. I also had to fit a heat shield around the brake servo for SVA man. so you could also look at doing this now as well. Are you fitting a remote oil cooler. This is another job you could prep by drilling and tapping mounting holes etc. Good Luck and enjoy.
CHEERS
LEE
DAX Cobra on the road now starting the build of a Tornado GT40. This car building lark is very addicitve.
Old 22-08-07, 02:46 PM
Sparticus's Avatar
Lee can you send pics of the heatsheild please?
Si
Old 22-08-07, 11:53 PM
I'll take a photo and put it here no problem.
CHEERS
LEE
Old 28-08-07, 10:10 PM
Sorry it took so long.
CHEERS
LEE
Old 28-08-07, 11:34 PM
Sparticus's Avatar
Thanks Lee,
Will have to make one, the heat from my exhaust melted my last servo hose.
Si
It's nearly ready FatBoy General Cobra Discussion 185 26-01-08 10:26 PM
oil pressure drop cut off switch question bitsilly General Cobra Discussion 14 04-10-06 08:00 PM
Ready.. plod General Cobra Discussion 22 11-07-06 11:17 PM
Engine ready and on its way bogster General Cobra Discussion 10 15-02-06 04:56 PM
I didn`t drop the baby PAULGD General Cobra Discussion 0 11-12-03 07:51 PM
