Old 05-08-07, 05:11 PM
Carb questions
A few questions re my Holley carb (supplied new with Chevy small block by Brian Nichols of RePower). Firstly, can someone tell me if the outlet pipe at the bottom of the carb (see lower middle of pic) is the vacuum take off for the brake servo? The manual calls it a 'PCV Port'. Secondly, the carb seems to have a manual choke. Is this ignored or do you locate a cable discreetly under the dash? Thirdly, on the left of the pic is the DAX throttle cable. Have I mounted the bracket correctly? It gives the right line but the return spring provided is much too short. Perhaps that is for the pedal end? Also, DAX supplied a stud. Is this to replace the existing one of four holding the carb to the manifold so that the thread is long enough to accomodate the bracket?
More questions later on sensors but that's enought for now. Thanks
Bob
"If you're in control then you're going too slow - Mario Andretti"
Old 05-08-07, 05:54 PM
carb?
Sorry Bob, but that Holly is an Edelbrock. Where did this "last craftsman" bit come from? MIKE
Old 05-08-07, 08:28 PM
1. The throttle cable is on correctly. Had the same problem fitting the spring on mine so made up a bracket and fitted a second spring as well.
2. The port in your picture is to connect to the PCV, which is a valve which should be located on one of your rocker covers.
3. opinions differ but by far the vast majority of people don't connect up the choke and in fact remove as much of the mechanism as is poss.
HTH
Old 05-08-07, 08:40 PM
Mike. Yep, Edelbrock it is - senior moment. Craftsman? You decide when you see my finished car next year.
Tinka. Thanks for your helpful comments. But I'm still not sure about the PCV. Do you know what it stands for? And if this port does not provide a vacuum for the servo can you say where I pick up the vacuum for the servo?
Thanks - Bob
Old 05-08-07, 08:53 PM
Club Sec/Rep Liason
Thanks - Bob
Bob. PCV stands for Positive Crankcase Ventilation You should have a capped port (or two) in the manifold that you can use for the servo takeoff. Alternately the Edelbrock has another capped port at the front that you can use.
AK 427 351C T5wc
Old 05-08-07, 09:24 PM
dave's Avatar
Tuuurn up da bass.
Hi Bob.
I'll jus tie up all the other replies.
The port on the picture is usually used for the servo and there is another one at the front of the carb for the PCV valve. (PCV valve is something sticking out of one of your rocker covers (Probably the on on the passenger side on your engine with a 3/82 bore hose coming from it).
The longer stud is for swapping with the original stud in the carb base so there is enough thread to attach the throttle cable bracket that you have pictured.
The spring fits from a tiny hole in the throttle cable bracket to a small hole in bent plate on the throttle arm at the bottom(The throttle cable attaches to the top of this same plate using the nipple supplied with the cable). It will foul the cholke mechanism but will still work fine even though it brushes against it.
As said above you could remove all the cholke stuff as they can be more trouble than they are worth which would leave the return spring a clean run.
RE: "Craftman"
This would only count if you'd thought out all your solutions on your own.
Having said that, I had been thinking that you were asking questions about your build months or even years before you needed to know but it is now dawning on me that you are actually motoring ahead with your build at a pace that is far more rapid than the norm on here.
Keep at it. And good luck.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Old 05-08-07, 09:40 PM
dingocooke's Avatar
[quote=dave;200107]
RE: "Craftman"
QUOTE]
and were the only person on here with any craft skills......
Steve
We're here for a good time...
Old 05-08-07, 09:41 PM
Miket's Avatar
Fully Paid Up Grandad
You can use this capped off port for the brake servo.
AK 427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
Old 05-08-07, 11:46 PM
last crafsman/holley
And I,m the last of the Mohikans, but I do have servo fittings if you need one. .......Mike
Old 06-08-07, 07:39 AM
dave's Avatar
Tuuurn up da bass.
Mike and Mike.
If the carb has come from Repower (It does look that way) The pictures here show an additional vac port that Repower add. The original one should still be on the front of the carb.
Pro Dax Builder
Current builds:-
DB REPLICAS
What carb ceejayjay Engine Tech Tips & Questions 8 04-01-08 07:11 PM
Holley Carb Questions cliffords General Tech Tips & Questions 3 04-11-06 04:18 PM
Which carb is best for me? kayjayd General Tech Tips & Questions 23 08-04-06 08:26 PM
What Carb Mark S General Tech Tips & Questions 8 09-01-05 09:05 PM
Carb Set Up Sheik yerbouti General Tech Tips & Questions 8 10-09-04 07:23 PM
