| Quote:
I have this problem in a couple of places where i have used Jaguar nuts and bolts, i expected those to be ok but now im not sure. Mark. |
| Quote:
I had to stop the pin from turning and unwind one lock nut until there was equal thread past the nut at each end. It's made more difficult to judge as one end is inside the rear chassis member and you need a torch to see whats going on inside. You need 3 pairs of hands to get all the thrust washers, seals and gubbins lined up as well Im just about to change my diff so I'll be having this fun for the second time (?) cheers
__________________ Nick Remember - Careless torque costs lives. |
| Yes thats the ones Nick,the trouble is the hole in the chassis mount is only big enough for the threaded part of the pin as the pin is tapered . So the maximum amount of thread i can get through this is about 13mm and thats the problem...Maybe the holes needed drilling out??? Mark |
| Don't drill the holes out. The parallel part of the bolt should not pass through the hole. You could try counter sinking the hole slightly but dont forget there is a thick plate that goes on the back of the diff which also needs nut's on it. I cant remember what mine looks now but I do remember I used threadlock as well on the bolts and I installed rubber blanking grommets on the ends of the tubes. I did this as the powder coating inside the tubes was thinner than the rest of the chassis and I didn't want water getting in there and sitting at the bottom. I found some nice rubber grommets and held them in place with a smear of silicone sealer. I was not asked to remove them at the SVA test. Craig.
__________________ Dax Tojeiro, + 350 Chevy + Tremec box = no more money! Polishes to date = 17 Last edited by craggle; 23-08-07 at 05:38 PM. |
| Nick its a shame you have the TOG, the diff on my SRV8 took 2 of us 4.5 to change from start to driving it again. Its not easy but sometimes necessary. !!!!!!!!!!!!
__________________ Andy S (Maggot) SRV8 + CHEVY Isnt it a beautiful day - now watch some bastard louse it up ! |
| Quote:
I'l have to take the interior/seats/tunnel covers, battery, fuel tank etc out to iget the 3.54 diff in. Oh deep joy! There was I thinking a 2.88 PL diff would be OK when I built the car. Oh well you live and you learn. When I got the car on the road initally I thought it was fast. Now 500 miles later I've got used to it and want MORE acceleration. A case of too much is not enough I think! Cheers
| Jag lower rear wishbone mystery | martin_t | Engine Tech Tips & Questions | 3 | 10-10-07 08:43 PM |
| Front brake pipe brackets. & rear lower arm mods. | Andy302 | General Tech Tips & Questions | 4 | 26-10-04 08:30 PM |
| Jaguar Upper and Lower Wishbones | rover | General Cobra Discussion | 2 | 22-04-04 06:45 PM |
| XJS Front Lower Wishbones. | SIMONF | General Tech Tips & Questions | 1 | 02-12-02 06:44 PM |
| Jaguar lower front wishbones | David J | General Tech Tips & Questions | 3 | 01-12-02 10:12 PM |
