Old 30-08-07, 11:24 PM
slogger's Avatar
Dax Side-pipe mounting.
Been sorting the headers and side-pipes on the Dax and have come up with a small problem. Dax sent me two 'Spreader plates' that go under the seats. Two holes are drilled through the plate, the floor and the side-pipe mounting bracket and all bolted together.
The question is: Have you guys fitted these spreader plates along the floor, front to back, or across the car, left to right? Or have you just cut the mounts and welded them to the outer chassis rail and be done with it?
Any other way of fitting these?? Thanks for your comments in advance.
Ian DAX 454 Chevy
Old 31-08-07, 08:19 AM
Veteran polisher.
They fit across the car. One hole goes through the seat rail mounting bolts and the other one I put into the outer chassis rail with a 8mm Rivnut.
I can take pictures when I get back home this evening if it would help.
Polishes to date = 17
Old 31-08-07, 11:15 PM
slogger's Avatar
Cheers Craig. Pictures would be a great help. No hurry as I will not be able to get to the Cob for a few days.
Thanks again
Ian DAX 454 Chevy
Old 02-09-07, 10:37 AM
Veteran polisher.
As promised here is a picture of my sidepipe mounting plate.
I fitted the sidepipes to the headers then propped the back end of the pipes up on blocks of wood to get the final position. Fit the rubber block and the plate then mark and drill the chassis where the plate fits.
I have 3 bolts holding it on. One was the inner mounting bolt marked through the pre-drilled hole in the mounting plates.
The outer fixing is into the box section chassis through a large rivnut.
The other fixing is the bolt that hold the seat runner in position.
You may notice that the plates don't sit exactly parallel with the chassis member but angle slightly backwards. This was the best position to mount them without putting strain on the pipes or the rubber mounting block.
The stainless steel dome nuts on the mounts I added as I proffered the look of them to the standard nut and washer.
Old 02-09-07, 11:41 PM
slogger's Avatar
Thanks Craig. That seems to have answered my question. I wish my Dax looked as pretty as that underneath...
Ian DAX 454 Chevy
Old 03-09-07, 11:48 PM
Clarkson's Avatar
Speed junkie
Hey post up some pics of your progress??
David
2nd baby due 23rd Jan.
Old 03-09-07, 11:51 PM
slogger's Avatar
In good time my boy. In good time.
Just had to strip out the steering column and reposition it due to a measurement error. Lower column making contact with No8 header pipe. Arrrrr.
Ian DAX 454 Chevy
Old 04-09-07, 12:03 AM
Clarkson's Avatar
Speed junkie
I had that on mine, penny washers sorted that out!
Did you sort out the clutch slave etc or have you used Mr leaky??
Oh why have you not got your name down for the Classic??
David
Old 04-09-07, 12:15 AM
slogger's Avatar
a) Had to remake a steel plate that fits on the inside of the foot well and fill the old holes. A real bitch as I had remade the footwell to get rid of the other 25 attempts the builder had made to fit this.
b) Mr Leaky is tucked up in the garage! Wilwood slave in the process of being sorted. Modified release arm and now need to make up some sort of mount that can be fitted to the box or bellhousing.
c) The Classic.......Hmmm. Can't commit to this at the moment and don't want to mess Andy about. Cob may well be running by then but will be a liability.
Ian DAX 454 Chevy
Old 04-09-07, 12:23 AM
Clarkson's Avatar
Speed junkie
Just come in the Cob!! OR tin top,it's a good crack!
David
Side exhaust body mounting ceejayjay Pilgrim Sumo Technical Questions 4 04-09-07 08:52 PM
Side pipe mounting ??! PeteV General Cobra Discussion 5 01-01-06 10:47 AM
Side pipe mountings Paul B General Tech Tips & Questions 17 28-03-05 06:18 PM
Side Pipe diameter jeff Pilgrim Sumo Technical Questions 5 09-07-04 06:05 PM
side pipe repacking clive a brown General Cobra Discussion 9 10-03-03 08:04 AM
