| Tunnel (heat protection) I've read a lot about heat transfered through the tunnel. Certainly, my Caterham's tunnel was always very hot and quite oppressive when summer driving. I'd like to know if members line the tunnel with some kind of heat reflecting sheet and if so, the extent of coverage. I'm inclined to line the entire inside with something, but need a nudge in this direction. Any help will be greatly appreciated. Thanks. Bob
__________________ "If you're in control then you're going too slow - Mario Andretti" |
| Bob, I didn't line the tunnel and have not experienced any discomfort (after all most of the time driving in the UK you need all the heat you can get!!). I took the car down to Nice in June and again found no difficulties in temperatures about 30-32 deg and never noticed the tunnel getting warm. I did however line the engine bay and was advised by the spray shop to line the top of the front wings above the headers to protect the external paint. Can't prove either way whether this was actually necessary. The only thing I might go back and do is try to dampen the sound coming from the electric fuel pump that sits on the chassis to the rear of the tunnel. Can't hear it when I'm going (due to the engine noise) but on tick over it's quite noticeable. Regards SJ |
| Hi Bob I did line my transmission tunnel with the stuff on the top of this page. http://www.woolies-trim.co.uk/c-128-...eflection.aspx Can't remember if I got it from here but Think auto do a similar stuff but a bit cheaper. http://www.thinkauto.com/cgi-bin/sh0...575#aTTEC13575 I gave the bottom of the tunnel a good sand with coarse glass paper then applied brush on high temperature impact glue to both surfaces. don't be tempted to use Aerosol spray glue ever as it will fall off sooner or later. You need to do some creative cutting to get it round the shapes at the front but it is possible. Tunnel stays nice and cool all year round. Craig.
| Cool-It If you would like to line your tunnel you could use this product. http://www.nimbusmotorsport.com/Prod...=624&CATID=269
| Hi, A gap of air would be the best insulation that you can have. If you manage to get some very thing stainless steel and you rivet it with a gap of say 2 mm or more than you will be solve the problem. But do not forget all the holes or edges, like the shifter hole, an internal leather boot will do the job. When you have an under slung exhaust and you think that this is the origin of the heat, the solution is simple and very effective. Wrap the exhaust after the headers (section under the car) with the heat wrap tape. You will be able to touch the pipe with your hands. Regards, Cobra289
__________________ http://www.donostia.demon.nl Cobra289 Gallery "Improvement" means that you recognize previous mistakes! |
| Quote:
I have looked at this stuff in the past and would like to use it on the inner wings and brake servo area but not if it is going to peel off and fall on the headers! Sorry for the hijack Bob! |
| Thanks Guys. It's good, as ever, to hear what others do. I think I'll proceed without using any kind of heat barrier just now. I'll see how things go and if the heat build up is excessive then will reconsider. I've designed my tunnel so it can be removed easily by unfastening about 15 M5 bolts positioned along the lower flanges and perimeter of the engine bay. So, if I go down the heat proofing route there will only be the carpet/felt to worry about. On this point see next thread! Thanks again. Bob
| Tunnel run, | scubie | Events | 1 | 13-01-07 12:05 AM |
| Russian Tunnel | Al Jones | The Cockpit | 1 | 10-01-07 10:23 AM |
| Inner wing panel heat protection | TheUnixKid | Pilgrim Sumo Technical Questions | 3 | 02-11-06 11:19 AM |
| Transmission tunnel | richc | DAX Technical Questions | 14 | 30-10-05 12:12 AM |
| Light at the end of the tunnel? | robinj66 | General Cobra Discussion | 2 | 20-02-05 12:37 PM |
