  #201 (permalink)
Old 06-03-08, 11:29 AM
andicole0's Avatar
It takes how long!
Blasted edit timeout!!
Andi.
http://picasaweb.google.com/andicole0 - http://andiscobra.blogspot.com/ - http://www.tomsrush.blogspot.com/
Polishes to date = 2.
  #202 (permalink)
Old 06-03-08, 11:37 AM
Veteran polisher.
I would drill the holes personally Andi.
If they can replace the crossmember with a flat plate with two holes then your box section with two holes in it will be strong enough.
I would drill the holes larger and fit rubber grommets in place to avoid chaffing.
The picture you have seen is this one of my chassis. http://www.cobraclub.com/forum/attac...9&d=1203677505
Polishes to date = 17
  #203 (permalink)
Old 06-03-08, 01:03 PM
Per Ardua Ad Cobra
Andi, you might want to put the gearbox rear support plate in from under the chassis as opposed to from the top as you have it installed at the moment. Reason is to allow the gearbox/engine to be removed from the completed car without trashing/removing the interior to get at the gearbox mounts.
Nick
Remember - Careless torque costs lives.
  #204 (permalink)
Old 13-03-08, 12:17 PM
andicole0's Avatar
It takes how long!
Wiring harnesses.
Just been marking up the connectors on the wiring harness and got to the tacho connection, which says it mates up with the Instrument harness. Is this something that comes with the dashboard or something extra I have to create?
Cheers.
Andi.
  #205 (permalink)
Old 13-03-08, 12:25 PM
Veteran polisher.
It should connect straight to the connector on the back of the gauge.
  #206 (permalink)
Old 13-03-08, 06:37 PM
andicole0's Avatar
It takes how long!
Unfortunately not.
Andi.
  #207 (permalink)
Old 13-03-08, 07:09 PM
southenddave's Avatar
Originally Posted by andicole0 View Post
Unfortunately not.
Andi.
I think it does connect straight to the Smith gauges but yours look like ETB gauges.
Where's my fecking bellhousing????
  #208 (permalink)
Old 13-03-08, 07:44 PM
andicole0's Avatar
It takes how long!
They are ETB, both guages and harness are from Dax.
Andi.
  #209 (permalink)
Old 13-03-08, 08:28 PM
Veteran polisher.
I think my Smiths gauges had a short loom on them. I brought the other half of the Dax loom plug from Vehicle wiring products and attached that to the gauge loom. Simple enough to just plug in then.
It looks like you should have a plug for the back of the gauge that goes to flying leads that could then be joined straight into the Dax loom.
  #210 (permalink)
Old 13-03-08, 09:17 PM
andicole0's Avatar
It takes how long!
Thanks guys, it doesn't look as big a problem as I first thought. I'll ring Dax tomorrow and ask Simon. The manual says 'don't panic when you see the loom' and now I have labelled it all it doesn't seem quite so scary.
How have you guys clipped the main parts to the body?
Andi.
A few questions angus99 Newbies 13 21-11-06 09:18 PM
SVA questions... TheUnixKid Pilgrim Sumo Technical Questions 4 05-10-06 11:13 PM
More EFI questions tonym General Cobra Discussion 3 26-05-04 06:38 PM
More 302 Questions Two greens General Tech Tips & Questions 13 27-06-02 05:32 PM
Questions graham General Cobra Discussion 5 04-02-02 09:07 PM
