| I have a single hoop roll bar on the drivers side only how high should it stand above the bodywork? Cheers. Andi.
__________________ http://picasaweb.google.com/andicole0 - http://andiscobra.blogspot.com/ - http://www.tomsrush.blogspot.com/ Building a Dax Tojeiro, Chevy 350, Tremec TK05, 3.54 Powerloc diff. Should be done in a couple of weeks! Polishes to date = 2. |
| Something to keep DB happy. A spare glass fuel filter and a fuel pipe going over the chassis. Andi.
| Touchy subject So instead, I did the hoop bolts, replaced the fuel filter, moved the fuel pipe and put on the demister bits. I bought an expansion tank and some liquid rubber for the wheel arches. Been looking at getting the radiator back in, the bonnet stay brackets and the front lights. Also looked at and ignored the carpet fitting ! That looks a nightmare ![]() Andi.
| There the big rubber elbows for the outlets I assume. I was wondering if you fitted the heater with the pipes coming out forwards or backwards. I ran my pipes forward out the front of the footwell face. I mounted my washer bottle in the boot and ran copper pipe through the cockpit area towards the front. Craig.
| Quote:
As suggested by DB I think I'll mount the heater the other way around and feed the pipes out over the engine. Partly because I'd already put the water bottle on that front panel. Hope you're feeling better BTW. Andi.
| Cheers Andi Feel much better now and went into work today as normal. Not sure what it was but it wasn't pleasant Sound's like your car's progressing well now. Whens the SVA date? Carpet fitting's not too bad really. Lay it all in dry to start with then figure out which bits need to go in first then glue one bit at a time. Craig.
| A few questions | angus99 | Newbies | 13 | 21-11-06 09:18 PM |
| SVA questions... | TheUnixKid | Pilgrim Sumo Technical Questions | 4 | 05-10-06 11:13 PM |
| More EFI questions | tonym | General Cobra Discussion | 3 | 26-05-04 06:38 PM |
| More 302 Questions | Two greens | General Tech Tips & Questions | 13 | 27-06-02 05:32 PM |
| Questions | graham | General Cobra Discussion | 5 | 04-02-02 09:07 PM |
