  #31 (permalink)
Old 24-11-07, 03:08 PM
andicole0's Avatar
It takes how long!
Duh! just drill from the other side of the engine compartment
Although that doesn't solve drilling inside the chassis. I'm still thinking about that. I really need a 6mm drill bit that will fit a Dremel. If I had a lathe I suppose I could reduce the diameter of the bit shank - but I don't have a lathe.
Cheers.
Andi.
http://picasaweb.google.com/andicole0 - http://andiscobra.blogspot.com/
Polishes to date = 2.
  #32 (permalink)
Old 24-11-07, 03:28 PM
rich's Avatar
would something like this help
Clarke RAD 1 Right-angle Drill Attachment
You know it makes sense
rich.
All Things Cobra.Com
the cobra builders resource
  #33 (permalink)
Old 24-11-07, 04:30 PM
andicole0's Avatar
It takes how long!
It might, I see it's probably 107mm long which leaves me about 20-30mm for the drill bit in order to fit, I'll do some more accurate measurements.
Many thanks.
Andi.
  #34 (permalink)
Old 25-11-07, 12:23 PM
andicole0's Avatar
It takes how long!
I've managed to get the front brake pipes in and clipped. But the front nearside pipe seems to be rather too long, is it worth shortening or just leave it, maybe try to make a neater loop
Andi.
  #35 (permalink)
Old 25-11-07, 02:08 PM
Miket's Avatar
Fully Paid Up Grandad
Andi.
You will definitely have to shorten it without any loops, there's no way it will pass the SVA like that, perhaps another clip in the corner would also be advisable.
P.S I notice from the picture that the lower Fulcrum pin is put in from the rear, is that correct on a DAX ??? I only mention it as AK put there's in from the front with the nut at the rear.
AK 427 FOR SALE
AK427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
  #36 (permalink)
Old 25-11-07, 03:22 PM
andicole0's Avatar
It takes how long!
Thanks Mike I thought I'd have to shorten it. No idea about the Fulcrum pin as I didn't build that bit I'll go and have a look at the manual.
Cheers.
Andi.
Edit: The manual shows the fulcrum pin going from back to front the way it has been done.
  #37 (permalink)
Old 25-11-07, 03:25 PM
dave's Avatar
What's the point?
There is no reason it should fail the SVA. The pipe is secured at no more than 300mm intervals.
Would look much neater though.
To make life much easier you would be better off pulling that engine out so you can climb into the engine bay and do all the work you need.
There does seem to be a mindset that that there is an urgency to "Get the engine in" when in reality the engine is just a useless lump of metal unless all the other components are also fitted.
If you are planning on polishing up the cladding that will also be much easier without the engine or anything else fitted.
Mike. Is it actually possible to put the fulcrum pin in the other way around on the AK with the wishbones being straight?
They are this way on the Dax as the end of the pin/bolt is close to the steering rack gaitor and the nut end would foul.
The easy way:-
Pro Dax Builder
Current builds:-
DB REPLICAS
  #38 (permalink)
Old 25-11-07, 03:29 PM
Veteran polisher.
Mike
The lover pin is correct for the Dax because Dax use the original Jag steering arms on the upright and a rear mounted steering rack.
If the nuts were at the rear they would hit the steering rack as it moves.
Polishes to date = 16
  #39 (permalink)
Old 25-11-07, 03:33 PM
Miket's Avatar
Dave
The only reason I said it will fail is that the pipe loop from the last clip to where it connects looks as though it could be longer than 300mm
AK 427 FOR SALE
AK427 FOR SALE
Mike
AK Sportscars
355 Hauser Chevy
  #40 (permalink)
Old 25-11-07, 03:36 PM
Miket's Avatar
Originally Posted by craggle View Post
Mike
Good, just thought I'd mention it, just in case.
What's a lover pin
AK 427 FOR SALE
AK427 FOR SALE
Mike
AK Sportscars
355 Hauser Chevy
A few questions angus99 Newbies 13 21-11-06 09:18 PM
SVA questions... TheUnixKid Pilgrim Sumo Technical Questions 4 05-10-06 11:13 PM
More EFI questions tonym General Cobra Discussion 3 26-05-04 06:38 PM
More 302 Questions Two greens General Tech Tips & Questions 13 27-06-02 05:32 PM
Questions graham General Cobra Discussion 5 04-02-02 09:07 PM
