Questions arising
Rather than start a new thread for each question I think I'll ask them here.
These might sound a bit daft and please no rude answers. 1. Where do I stick the dip stick? 2. Brake fluid reservoir. The Dax manual says use a remote reservoir but I'm sure the master cylinder is supposed to have one attached. Again any pictures? Before I get too embarrassed I'll stop here. Andi.
http://picasaweb.google.com/andicole0 - http://andiscobra.blogspot.com/ Building a Dax Tojeiro, Chevy 350, Tremec TK05, 3.54 Powerloc diff. Should be done in a couple of weeks! |
Andi. I'll take some pix tomorrow and post them.
"If you're in control then you're going too slow - Mario Andretti" |
Andi,
The oil dip stick on mine is about half way down on the left hand side entering the block below the line of the cyclinder head. Mine has a chrome housing that pressure fits into the block. Your's may not have been fitted making it difficult to identify. The reservior for the brake and clutch fits as high as possible on the engine side of the cockpit bulkhead sensibly near to the clutch cylinder and brake servo. I used chrome tubing over the bolts to move the mounting bracket out from the lip of bonnet to allow for easy access to the reservior cap. Regards SJ |
Pics would be good especially where it enters the engine. I have a chrome tube with the dipstick which looks like it press fits. Picture attached.
Thanks. Andi.
Hello Andi,
Take a look at this link. There are both types. Late: 1980 on http://www.kennysrodshop.com/parts/b...c_ramjet_d.jpg Early: up to 1979 http://www.kennysrodshop.com/parts/b...79dipstick.jpg Regards, Marc
Dax Tojeiro fully galvanised chassis! Painted in Ferrari Tour de France blue 1975 SBC 350 / Tremec T5 On The Road. Yupee! http://www.cobraclub.com/gallery/sho...00&ppuser=1245 |
Thanks Marc, I found it, I think.
Mike, looks like mine is on the off side. Blimey that engine of mine needs some TLC Andi.
http://picasaweb.google.com/andicole0 - http://andiscobra.blogspot.com/ Building a Dax Tojeiro, Chevy 350, Tremec TK05, 3.54 Powerloc diff. Should be done in a couple of weeks! Last edited by andicole0; 15-11-07 at 08:15 AM. |
Dip stick issue looks as if all ok now ?
ref the reservoir fluid - no matter if remote or attached, the lowest point of the reservoir should be higher than the highest point of the master cylinder. basic fluid dynamics - if the reservoir fluid level falls below the master cylnder inlet then a low fluid level could permit air into the system. A master cylinder with reservoir attached is usually the best way to go as it eliminates any additional pipe work or fittings that could cause leaks or trap air. Downside is usually the size where space may be limited. suspect thats why its recommended to use a remote as this can be located somewhere more accessable for filling
Chris Lutman - Daytona Coupe |
Andi.
A few pis attached as promised. They say nothing different from other members but just help confirm. Bob
Thanks for the brake pictures, it's all clear now
I've attached a pic of the dipstick temporarily placed in it's hole. As a matter of interest how are these things calibrated ? Cheers. Andi.
| A few questions | angus99 | Newbies | 13 | 21-11-06 09:18 PM |
| SVA questions... | TheUnixKid | Pilgrim Sumo Technical Questions | 4 | 05-10-06 11:13 PM |
| More EFI questions | tonym | General Cobra Discussion | 3 | 26-05-04 06:38 PM |
| More 302 Questions | Two greens | General Tech Tips & Questions | 13 | 27-06-02 05:32 PM |
| Questions | graham | General Cobra Discussion | 5 | 04-02-02 09:07 PM |
