Old 27-04-08, 09:37 AM
oiler0 oiler0 is offline
Dax Front Roll Bar Bushes
i have just replaced my old rubber front roll bar bushes as they where perished from sitting in the garage for over twenty years.
with the new polly type of bushes
my problem is that i know that their is no weight on the front end but i just douse not look right to me
is their any setting up or shimming required on the front roll bar assembly as it all seams all very tight and on the piss
see picture ?
thanks oiler0
Old 27-04-08, 12:18 PM
craggle craggle is online now
Veteran polisher.
Looks like the car was off the floor when you took that photo.
They straighten out once the weight is on the wheels and the wishbone moves up a bit.
Polishes to date = 14
Old 28-04-08, 03:48 PM
427scr's Avatar
427scr 427scr is offline
Agree with what he said
Old 04-05-08, 02:42 PM
Question front wishbone offset ?
i have just about finished rebuilding the front end on my DAX standard chassis.
but looking at it i think i have made a bit of a major mistake.
can some one please confirm to me which way the lower offset is pointing on the lower jag wishbone
is the offset pointing to the front or the rear of the car ?
thank,s
oiler0
Old 04-05-08, 05:33 PM
Veteran polisher.
I'm 99% sure the crank should be facing towards the front of the car. Your photo is of the drivers or offside so it looks wrong.
Sorry
Old 04-05-08, 08:06 PM
Richard Gibbs Richard Gibbs is offline
Ditto to Craig's point. The crank should point forwards on the XJ6/XJS lower wishbone. I made the same mistake and recognised it before getting too far. You wont be able to set up the suspension correctly unless you change it. Hopefully not too long a job.
Richard
Dax - Standard Chassis, 383 Stroker (Tremec TKO v. soon)
Old 04-05-08, 10:09 PM
slogger's Avatar
slogger slogger is offline
Dax manual shows the offset being forward. Sorry mate. Better sorted now.
Ian DAX 454 Chevy
Old 10-05-08, 01:24 PM
hi
guy,s
just re built the front end this time with the wishbones on the right side ,,,i hope ?
so i back to where i was last week now
i was just wondering
i presume that i have the bracket that fixes to the lower wishbone and the front drop link roll bar is on the right way round
see my last picture as this is how i have put them on ?
oiler0
Old 10-05-08, 02:19 PM
Veteran polisher.
There the same way round on my car as in your picture.
Old 10-05-08, 04:01 PM
dave's Avatar
dave dave is online now
yippie ki ay mutha f****r
Wrong in both pictures. (The second picture does have the same picture/camera no. as the first one though).
There were two types of lower wishbone, A straight one and the angled one pictured here. The angled one should be cranked forward.
Pro Dax Builder
Current builds:-
Dax No.123---------Kirkham No. 1
DB REPLICAS
Jag front suspension bushes/movement nbracken General Tech Tips & Questions 9 24-11-05 05:41 PM
How well do bushes age? bitsilly General Cobra Discussion 3 05-11-05 11:01 AM
Bushes CeeJay General Cobra Discussion 5 18-05-05 08:45 AM
DAX anti-roll bar bushes/rubbers ian General Tech Tips & Questions 2 09-07-03 01:57 PM
bushes John Chambers AK Technical Questions 9 31-01-03 06:44 PM
