Old 05-05-08, 09:23 AM
C.Rogers's Avatar
C.Rogers C.Rogers is offline
Rattling Exhaust
I finished my De Dion about 9 months ago, and since more or less first start, there has been an almighty rattle from the near side exhaust.
I have taken the tail pipe off and checked the baffle, and all seems fine to me. Although i am no expert...
Has anyone else had any similar symptoms or got any suggestions as to what could be causing this rattle.
It spoils the wonderful sound of the V8
Old 05-05-08, 06:12 PM
dave's Avatar
dave dave is offline
Hammer time
The front end of the baffles is not tight enough in the pipe.
Slide the baffle out, distort the trumpet end slightly and then push it back in.
That should do it.
Pro Dax Builder
Current builds:-
Dax No.123---------Kirkham No. 1
DB REPLICAS
Old 05-05-08, 06:14 PM
Nobby Nobby is offline
Same on my Dax pipes. I took them apart and the front of the perforated baffle pipe is loose inside the front cone section of the collector. The rattle stops when the pipe gets hot and expands. Haven't thought of a way of stopping it other than drilling a hole from underside and screwing a threaded rod into the pipe to butt against the baffle. Anyone got any better ideas?
Nick
Remember - Careless torque costs lives.
Old 05-05-08, 06:15 PM
That should do it.
Blimey that was quick. Good idea.
Nick
Old 05-05-08, 07:03 PM
craggle craggle is online now
Veteran polisher.
I welded a nut to the baffle cone and then drilled a hole in the bottom of the side pipe. A small stainless screw and some loctite holds it all tight.
Polishes to date = 14
Old 05-05-08, 08:01 PM
Wilburn's Avatar
Wilburn Wilburn is offline
Just a long shot, I had the same thing about a year ago but it wasn't the exhaust it was the fan thats part of the alternator that had snapped off and was rattling.
It probably IS your exhaust but worth checking the alternator fan.
Paul
DB Replica build 98 - Dax De Dion - Huddart Engine - 383 stroker - 450 bhp & 470 lb/ft
Visit my Cobra photo gallery at www.paulwilburn.co.uk
Old 26-05-08, 04:51 PM
mattymouse's Avatar
mattymouse mattymouse is offline
Had my baffles out due to a small rattle on one of them. I just left them out til the other day and boy is it quiet now.
Anyway, I cant remember if the cone section goes at the front or rear of the pipe. I put it at the rear, is that wrong? Would it do any harm if so?
Matthew
Old 26-05-08, 06:25 PM
Veteran polisher.
Cone should be at the front to funnel all the gasses from the 4 headers into the centre of the perforated tube.
Old 02-06-08, 08:39 AM
C.Rogers's Avatar
Rattling Sorted !!!
We have fixed the rattling exhaust.
The trumpet end was a nice fit in the exhaust, so it wasn't that.
What it actually was, was the mesh tube was slidding up and down inside the exhaust and rattling around. It was sliding so much that it was marking the inside of the tail pipe.
To solve it, we put a jubbilee clip on the mesh (not too tight at first), re fitted the tail pipe so that the jubbilee clip slid down the mesh until the tail pipe was in it's final position. The pipe was then removed and the jubbilee tightened.
Problem Solved
It is ammazing how much difference it has made to the exhaust note. It's awesome!!!!
Thanks again for your suggestions.
Exhaust help Tidyshed Pilgrim Sumo Technical Questions 5 28-03-08 03:04 PM
Side Pipe Rattling driving me nuts BenBaron General Tech Tips & Questions 14 19-10-07 09:01 AM
Exhaust 427sc General Cobra Discussion 7 09-01-06 10:34 AM
exhaust! shiney DAX Technical Questions 7 30-09-05 04:37 PM
Rattling Cat TonyD General Tech Tips & Questions 7 04-11-03 04:35 PM
